Old 10-29-2009
QuickMick's Avatar
QuickMick is on a distinguished road
removing hardware is hard! hellllpppp!
These two hurricane boats ive been stripping for parts have a lot of good usable stuff... the problem im running into is removing the mounting plates... ie on the ~ 8" cleat, i pull the bolts and the cleat no problem, but on the mounting plate, there is some type of adhesive to the hull that is problematic.
also, on the Hunter i'm scavanging the port hatch in the head is in fine shape, but even after screw removal i cant seem to pry the stinker off and dont want to apply so much force as to break it.
are there any type of solvents i can use to soften this up? or any tricks that might help me?
i appreciate your help,
Quinn
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 10-29-2009
timebandit's Avatar
timebandit is on a distinguished road
A guitar string between two pieces of Dowling make a good flexible saw for cutting through sealant.
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
Old 10-29-2009
catamount's Avatar
catamount is on a distinguished road
For the Backing Plates, I would use an chisel and a big hammer -- they may be epoxied in place. You could try heating them a bit with a propane torch and then the chisel to break them loose from the underside of the deck. Or just leave them -- it's the hardware on top of the deck that is most valuable, people buying this stuff can likely make their own backing plates!
Regarding a solvent for the hatch sealant, you could try Boat Life's "Release."
Peterson 34 GREYHAWK, West Boothbay Harbor, Maine
, a new voice for ocean conservation
Old 10-29-2009
badsanta is on a distinguished road
If your trashing the rest of the boat, I would try a chainsaw and a mask.
That derelict boat was another dream for somebody else, don't let it be your nightmare and a waste of your life.
Old 10-29-2009
KeelHaulin's Avatar
STARBOARD!!
KeelHaulin will become famous soon enough KeelHaulin will become famous soon enough
These boats are owned by you or are in a boat junk yard, correct? I mean we are not helping you to scavenge parts/pieces from boats that might have owners, correct? If you are stripping parts from a wreck please be sure that you have the right to do so; otherwise you could be considered a "looter".
Old 10-29-2009
mitiempo's Avatar
If you have the right to remove hardware and the boat is really junk use either a jigsaw, sawzall, or as mentioned chainsaw to cut around the hardware and do the detail cleaning at home. Wear eye protection.
Brian
Old 10-29-2009
Capnblu is on a distinguished road
Thin wide screwdriver, tap in lightly, fish fillet knife, slice a little, gently insert thin wide screwdriver a little further, back and forth working slowly. I have also used a piano wire, and pulled if you have access to get it through. If you are dealing with butyl, use regular paint thinner to soften the butyl and lubricate your fillet knife, or piano wire. just go slow with the prying, or you will find yourself with a pile of bent junk.
Why, why, why?
Old 10-29-2009
CharlieCobra's Avatar
On the hard
CharlieCobra has a spectacular aura about CharlieCobra has a spectacular aura about
A multimaster with plunge blade will help if the boat is junk.
Baggett and Sons Marine Restoration
The Landing at Colony Wharf
Bellingham, WA.
Old 10-29-2009
fpr's Avatar
fpr fpr is offline
fpr is on a distinguished road
Sorry Quinn,
Couldn't answer your PM 'cause I don't post 'enuf' for the powers that be....
The answers are right on.... you'll need many different techniques to strip the boats. Every bedding compound will require a different attack method.
My favorate tool combo is a razor sharp 2 inch wide chisel and a 20 ounce hammer.
Patience and educated blows will separate just about everything;
Except stuff like 5200....
That s--t is designed to be forever....cut it with a metal SawsAll blade.
Cleats, chocks, bow rollers, stanchion bases, chain plates etc. are pretty tough.... if you want to break one you couldn't....
Remember these hulls are scrap and you'll probably not be able to save everything.
I never ran into anything I couldn't remove with sweat or a SawsAll...
fred
There's no bigger fan of the opposite sex than me, and I have the bills to prove it.
Old 10-29-2009
tager's Avatar
tager is on a distinguished road
I think if you get a good industrial paint stripper it will melt just about any polymer. Wear respiratory protection.
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
