10-30-2009
Originally Posted by KeelHaulin
Teak is not immune to weathering, wear, UV damage or rot. The problem with un-finished teak (aside from decks and cockpit grates) is that when you don't keep it finished it weathers, dries out, cracks, splinters and in some cases does rot. I've seen many boats like mine of the same vintage that left their teak un-finished and at 30 years of exposure the original trim looks horrible and should be replaced entirely.
So please, let's keep the bashing of finished teak to a minimum; it really does preserve the wood regardless of what people might tell you to the contrary. A teak deck should not be varnished and it's lifespan is well known at somewhere between 20-30 years (unless the planks are 1" thick).
min eis treated ----is just treated gently with sea water and oil......clean and pretty not shiny and slick....
