sanding teak - SailNet Community
Blogs
Old 10-29-2009
QuickMick's Avatar
QuickMick is on a distinguished road
sanding teak
Ive got teak trim on the boat, needs rehabed (not annual maintainence), is there any reason [I]not[I] to use an electric sander and do it all by hand? ive been working by hand, sanding to the sandy bottoms and this may take the rest of the year!
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 10-29-2009
deniseO30's Avatar
Lies about her age
if it's really bad, I'd pressure wash it and use teak cleaners a couple of times. You don't want to use too high a pressure and use the "fan setting" on the nozzle. it will save you hours, but I'd still use a sander. 220 is the last paper I use before applying cetol or varnish.
Old 10-29-2009
mike dryver is on a distinguished road
make sure you wear a mask as the silica in the teak may irritate your resp. system. and what Denise 030 said
Old 10-29-2009
T37SOLARE's Avatar
Tartan 37C
T37SOLARE is on a distinguished road
If your removing an old finish, start with a heat gun & scraper, then sanding with a oscillating sander like the MultiMaster works great.
Fein MultiMaster FMM 250 Start
SOLARE
T-37 #442
Old 10-29-2009
KeelHaulin's Avatar
STARBOARD!!
KeelHaulin will become famous soon enough KeelHaulin will become famous soon enough
It depends on what you are sanding. Could you describe it or post up some pictures?
I had a difficult time sanding the varnish off of my teak coaming; ended up using a belt sander to get the bulk of the finish off; then hand sanded the edges and areas where the sander could not reach. The wood sands away quite fast so be careful when you get to that last bit of finish or rough wood.
Old 10-29-2009
swadiver's Avatar
swadiver is on a distinguished road
QM,
I'm just finishing varnishing all of the teak on my boat. A heat gun is a must if you have access for the scrapper. Always draw the scrapper towards you and lift up the gun so you don't burn the wood. Or, chemical stripping if no access for the scrapper. I start with 80 grit and work up to 220 with an electric sander (not a belt sander). It is allot of work but looks good. Good luck.
Scott
Long Beach, Ca.
s/v Namaste - 86 Catalina 30 , Tall Rig
The optimist expects the wind. The pessimist complains about the wind. The realist adjusts the sails.
Old 10-29-2009
Well-wisher
pschoonveld is on a distinguished road
You do not want to pressure wash teak or any other wood. People do this with decks (as in backyard, not as in boat) frequently and it causes the wood to break down and fuzz to appear. Here is a good article that describes what happens: Proper Teak Care
T37 makes the best suggestion. Heat gun to remove varnish and then sanding with any tool you'd like.
Old 10-29-2009
KeelHaulin's Avatar
STARBOARD!!
My suggestion for use of a belt sander was only to remove bulk layers of varnish instead of a heat gun or chemicals (on large flat surfaces). You must not use a belt sander on delicate veneers or on raw wood. I suggest using a linear sanding method like hand sanding with a sanding block instead of a vibrating tool so you don't end up with swirl mark scratches in the wood; which can be impossible to remove without over-sanding (hence the reason I went with the belt sander on the coaming, it was quick and trouble-free). If you put swirl scratches in the wood you won't be able to remove all of them and it will always show beneath the finish.
Final sand with 400 grit (220 is just a little too coarse IMHO) before the first coat of finish and between coats; and wipe the wood with an acetone soaked rag before putting down the first coat to remove oil from the wood.
Old 10-29-2009
mitiempo's Avatar
I think while a belt sander could be used if you're experienced, in the wrong hands it can do a lot of damage. A small vibrating sander is less likely to do this damage. Finish by hand sanding with fine grit with the grain. A heat gun, again used carefully, with a good scraper will remove the bulk of the old finish first.
Brian
Old 10-29-2009
whigmaleerie is on a distinguished road
theres no great way to do it just get on with in many hands make light work a good quality orbital sander will work a treat, belt sanders are great in the workshop but on trims i dont think so!!!!!!
Little Harbor 38 Kerwood Boat Review and Purchase Forum 11 08-27-2007 07:49 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 08:00 PM
Homemade Teak Decks, Part Two SailNet Gear and Maintenance Articles 0 10-02-2002 09:00 PM
Homemade Teak Decks SailNet Gear and Maintenance Articles 0 08-01-2002 09:00 PM
Bristol Teak Tom Wood Gear and Maintenance Articles 0 11-02-1999 08:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
