Old 10-30-2009
Twoowls is on a distinguished road
Post Fuel Gauge Morgan 30
Any ideas about a gauge that will work? The tank is approx 15 gallons, gas and installed just under the cockpit. Somewhat difficult to access. Suggestion would be most welcome.
Old 10-30-2009
JimsCAL's Avatar
JimsCAL is on a distinguished road
A standard sender and gauge from Teleflex or Moeller is the common choice. The sender is mounted in the top of the tank and they can be adjusted for the depth of the tank. Total cost under $75.
Old 10-30-2009
Smile Thanks!
Really appreciate the info. Just hope I won't have to disassemble the boat to get it in.
Old 10-31-2009
JimsCAL's Avatar
The toughest part may be getting the sender in the tank. Many tanks will have a standard SAE opening in the top. If not, you will have to cut one. I would guess you need at least 6 inches clearance from the top of the tank to the bottom of the cockpit floor to get the sender in. I replaced my fuel tank sender this spring. My tank is also under the cockpit and it was a bit more difficult than I expected due to the tight overhead clearance.
Old 11-02-2009
Leither's Avatar
Retired and happy
Leither is on a distinguished road
Just a thought. I have the same boat with the same set-up and I use a wooden stick gauge which cost me precisely zero and there were no installation problems. I have it marked out to indicate "full". "3/4 Full", "1/2 Full", "1/4 Full". It takes only seconds to take a reading and I have never come near to running out of fuel!
Stuart
Leith (rhymes with teeth) is the port of the City of Edinburgh in Scotland. A Leither is someone who comes from that area.
I must go down to the sea again, to the lonely sea and the sky - I left my shoes and socks there, I wonder if they're dry?
Old 11-17-2009
Smile Dip Stick Fuel Guage
Love the wooden stick. Use something similar on the race car and the airplane. However, the fuel filler is behind the tiller and goes through a hose to the tank. Don't know where I can get the right curved stick. Perhaps Australia?
Old 11-17-2009
Leither's Avatar
Retired and happy
Hah! Seves me right for assuming that your fuel filler was in the same location as mine - slap bang in the middle of the cockpit floor! However, I must admit I posted mainly for the entertainment value of my stick gauge......
Happy measuring
Stuart
Old 11-17-2009
pegasus1457's Avatar
Arf!
pegasus1457 is on a distinguished road
Is there any kind of gauge there already?
If so, Moeller makes a converter capsule that screws onto the existing mechanical gauge and provides a resistive "output" to connect to a remote gauge.
Otherwise, check the WEMA SSL line of senders.
This was discussed in a recent thread which I started. You may find some useful ideas there:
http://www.sailnet.com/forums/diesel...ggestions.html
Fluctuat nec mergitur
Old 11-18-2009
mitiempo's Avatar
I agree with pegasus. The Wema sender is better than the older angled arm and float type. I have one on my new stainless tank and no complaints at all.
Brian
fuel gauge -- any suggestions? pegasus1457 Diesel Engine Forum 24 11-28-2009 03:01 PM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Diesel Fuel Concerns SailNet Gear and Maintenance Articles 0 07-08-2002 08:00 PM
Cleaning Fuel Tanks Sue & Larry Gear and Maintenance Articles 0 03-21-2002 07:00 PM
