Old 10-31-2009
I'd rather be sailing
labatt will become famous soon enough
Nav Station Blank Plate
We're looking to convert a portion of our nav station to support additional instrumentation. I'd like to put a face plate on the area so we can create a clean look, with all of the instruments (VHF, SSB, ST70 and NASA Barograph) mounted into it. I'm assuming the black plates I see on new boats are black anodized aluminum? Does anyone know anything about them, and where I can buy blanks? We can mill it to the appropriate size, which will be 11 x 17.75, but I need to find a piece to start with. Any ideas?
Thanks!
Chris
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
Old 11-01-2009
dugout is on a distinguished road
FRP is a lot easier for most to work with...
McMaster-Carr
Just a suggestion.
Old 11-01-2009
nickmerc's Avatar
nickmerc is on a distinguished road
When I redid my electrical panel it was black powder coated aluminum. Anodizing can scratch very easily and if you rub another bare metal against a mark will be left. I like aluminum because I can, if need be, put threads in it to mount stuff. If you are going to pursue this course, get the aluminum, mill it to size, then bring it to a custom bike or car shop. They should be able to powder coat it for you.
________
Web shows
Old 11-01-2009
GaryHLucas is on a distinguished road
Over the years I've made quite a few control panels, and Ihad stuff poweder coated and black anodized. I think its more of a choice of what look you want, they'll both hold up pretty well. However despite the fact I can do this myself I don't think I would. If you look in the experimenter electonics magazines (Circuit Cellar Ink comes to mind) you'll find advertisements for companies that produce one off face plates. They can not only cut and finish, but silkscreen legends on them too.
Gary H. Lucas
Old 11-02-2009
Thanks... I was hoping there might be sources of the panels, blank, out there. I need to get this project started and finished this week
Old 11-02-2009
WinterRiver's Avatar
WinterRiver is on a distinguished road
The panel our boat came with is black starboard or equivalent. Looks good, easy to work with.
Hylas 47
Old 11-02-2009
Cruisingdad's Avatar
Best Looking Moderator
Thanks!
Chris
Chris,
How are you guys? We need to catch up and speak and see about meeting down south!
Anyways, I just redid all of my panels/electronics. We used 3/4 inch plywood (of your choice) covered in a sheet of black melamine. It is VERY easy to do and very inexpensive. It looks goot too. I will show pics when I bring the camera back (it is a tthe boat now). You can buy all the stuff at Home Depot.
Talk soon,
Brian
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Old 11-02-2009
goboatingnow is on a distinguished road
Frontpanelxpress.com
Note I agree re anodizing, its scratches very easily, and can discolour with age( mine did where sunlight fell on it). poweder coat is much stronger.
The plywood melamine isnt bad either, it can be a bit of a nuisence to mount switches and stuff that cant handle think panels.
Old 11-02-2009
Thanks all... I think for the moment (since we're looking to get SOMETHING done quickly) we're going to (don't laugh) go with 0.25" aluminum that's spray painted flat black. The aluminum is only $15 and the rigidity is good for the mounting of the VHF and SSB. Ultimately, I think we'll be looking to powder coat aluminum. CD - we thought about melamine but wanted flat as opposed to glossy, plus there are some limitations with regards to thickness on the instruments. We can't find a source of black starboard that's cost effective and available. So... for now, aluminum and spray paint . I'm going to check out frontpanelexpress though...
Old 11-02-2009
mitiempo's Avatar
Both Arborite and Formica panels are available in both glossy and flat finishes.
!/4" or 3/8" plus the laminate is plenty strong enough.
Brian
New Margate Coastguard Station @ Sea Dreamer NewsReader News Feeds 0 04-19-2006 03:15 PM
Nav Station Facing? ian6460 General Discussion (sailing related) 7 07-31-2004 05:52 PM
Using Tidal Current Tables Jim Sexton Seamanship Articles 0 01-27-2004 07:00 PM
Using Tidal Current Tables Jim Sexton Gear and Maintenance Articles 0 01-27-2004 07:00 PM
Setting Up Your Nav Station Sue & Larry Gear and Maintenance Articles 0 07-26-2002 08:00 PM
