Dipole resonance - SailNet Community
Blogs
Old 10-31-2009
wind_magic has a spectacular aura about wind_magic has a spectacular aura about wind_magic has a spectacular aura about
Dipole resonance
This is directed to btrayfors because I know he'll be able to answer it, but please, anyone who knows the answer to this respond, I could use the help!
When building a dipole, once the math and cutting is done, how do you actually tune the dipole to the right length, etc, so that you know with certainty that it is resonating as well as it can ? What test equipment do I need to tune the dipole, and what is the best method for tuning it since I know that once you cut the wire it is cut and not easily made longer.
Thanks!
What are you pretending not to know ?
Old 10-31-2009
btrayfors will become famous soon enough btrayfors will become famous soon enough
I posted directions for tuning a dipole on the SSCA Board a few years back. Here it is: SSCA Discussion Board • View topic - How to Tune a Marine Dipole Antenna
I presume you're talking about a vertical dipole for marine use. If so, it will be considerably shorter than the formula, but it's best to begin at the formula lengths, then successively trim each end back by an inch or two and try again until you get the lowest swr.
An antenna analyzer would be a help, but you can do it with just an swr meter by tuning quickly below the desired frequency to see where the antenna is "resonant" NB: resonance isn't the same as lowest SWR, technically, but for our purposes let's pretend they're the same.
You'll be tuning below the desired (formula-cut) frequency because you know that the antenna is too long. So, blow softly into the mic and tune quickly down the bank and watch the swr go down. If it begins to go back up again, you'll know you've passed the point of "resonance".
As you get the antenna cut so it's now "resonant" within the desired ham band, then cut the ends VERY LITTLE....a half-inch or an inch at a time...until you bring it up to the desired frequency.
Be sure to have a bottle of Mt. Gay handy. This is a tedious process without an antenna analyzer, but the Mt. Gay helps to make it fun :-)
Bill
Old 10-31-2009
rikhall's Avatar
old guy :)
rikhall will become famous soon enough
Or you could bribe some old fart HAM radio operator to come and "help" you tune it.
"Hey - I have a problem and I am not sure I if you can help (old HAMs love helping others). I've made this dipole antenna thing (old HAMs love "home made" things) and I don't know how to tune it."
And like Bill says - have the Mount Gay or Lagavulin handy to help the process.
Rik
VE9RIK
Irwin Citation 34
FCC Drops Morse Code Requirement! hellosailor Gear & Maintenance 45 12-20-2006 02:01 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
