Rotten core around Mast Step-repair - Page 6 - SailNet Community
post #51 of 53 Old 10-25-2010
mitiempo's Avatar
If you removed all the moist core it should work. But if not the moisture left will cause rot and with freezing cause delamination as well. By using epoxy in the holes you drilled any future repair becomes much tougher to accomplish.
Brian
mitiempo is online now
post #52 of 53 Old 10-25-2010 Thread Starter
There really isn't anything left to rot in there as the entire core was totally rotted. After sitting with a 2 foot section cut out at the mast step for the winter it was fairly dry (after the -50 weather we had this winter it was freeze dried). My hope is that there is enough fiberglass in there that is bridging the inner and outer skin that it will keep for years to come. If it does fail it will mean removing the whole deck but repairing it properly would have meant that anyway. Here's hoping.
superiorvoyager is offline
post #53 of 53 Old 11-04-2011 Thread Starter
After 2 years of heavy sailing my solution has been holding up well so for someone who doesn't want to replace an entire cabin deck this may be an ok solution.
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
Deck Stepped Mast or Keel Steeped Mast??? tbeargladd General Discussion (sailing related) 36 11-14-2007 08:07 AM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
what mast? jrwright Boat Review and Purchase Forum 3 03-14-2004 08:19 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
