Winterizing propeller shaft seal - Page 2 - SailNet Community
Blogs
  #11 (permalink)
Old 11-03-2009
pkats is on a distinguished road
Thank you for reply. I am located in NJ and I am hauling out. Thanks again for the advice
  #12 (permalink)
Old 11-04-2009
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
We have a traditional stuffing box on our boat and I have never worried about winterizing the cutlass bearing (exit point of prop shaft on hull). As others have said, water gets in and acts as a lubricant when in the water. Once the boat is pulled out most of the water drains out due to gravity leaving only a small amount as our shaft is pitched down and aft. Air can get in around the small interstices of the cutlass bearing and the shaft and there is plenty of room for ice to expand (we are probably due for a new cutlass bearing).
If you have the PSS dripless shaft gizmo you might be able to sneak a little pink RV anti-freeze in there. Most people seem to have more pressing winterization issues to deal with as there are many, but this is not a big one IMHO.
Shaft seal Edo Kazumichi Gear & Maintenance 9 11-23-2006 12:03 PM
Packless Shaft Seal (PSS) bkdehuff General Discussion (sailing related) 4 04-20-2004 06:41 PM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 08:00 PM
The Stuffing Box and Stern Tube Tom Wood Gear and Maintenance Articles 0 04-27-1999 09:00 PM
Check the Propeller Tom Wood Gear and Maintenance Articles 0 02-25-1999 08:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
