Old 11-04-2009
JESTER458 is on a distinguished road
building a bulkhead
ive been doing some reading about installing a new bulkhead and noticed people using a foam to separate the wood from the hull (to eliminate hard spots on the fiberglass) but what i cant figure out is what type of foam is this they are using?? any help would be greatly appreciated
Old 11-04-2009
Usually a structural foam like airex or maybe klegecell - not your standard home depot blue styro!
1984 Fast/Nicholson 345
Old 11-04-2009
dakuehn's Avatar
dakuehn is on a distinguished road
Many builders use rubber gasket material--I'm sure you could find a suitable replacement material at a big box store.
Old 11-04-2009
awesome thanks! (funny because i just had someone tell me it was blue stryo from homedepot haha i didnt think that could be right... )
Old 11-04-2009
hey quick question, you said airex, which from what i can see is actually a softer foam (like exercise mats) did you mean airlite?
(nevermind i just found a rigid airex foam)
Old 11-04-2009
mitiempo's Avatar
You can use any kind of foam you like. Tim Lackey at The Triton Daysailor | From a Bare Hull:* Bulkheads
uses blue foam like you purchase at Home Depot. The reason for the foam is to keep the edge of the bulkhead away from the hull until you glass it in. That way the load is all on the glassed in tabbing and not against the bulkhead at any point. You could glass one side and then remove the foam (not that you're likely to though) before glassing the other side. It's purely a softer than wood spacer. I've used ethafoam just because I had some around but anything works as well. The link above takes you to a page documenting a bulkhead installation complete with pictures.
Brian
Old 11-05-2009
oh ok. and thats actually tha article i was reading earlier too! thanks for the information.
Old 12-19-2010
Greenflash35's Avatar
Greenflash35 is on a distinguished road
Both the Klegecell and Airex Rigid foams look stiff. The foam in the Triton Project appears flex able "contouring to the hulls form". Could it be the exercise mat used as the spacer?
GreenFlash35
Old 12-19-2010
CapnSantiago is on a distinguished road
Where did you find the airex material? How stiff/flexible is it?
CapnSantiago
Lake Texoma
1982 Islander Bahama 30
Old 12-19-2010
Just cyber shopping the Airex and Klegecell. I don't have any experience with ether product. Would like to here some feedback from someone who has accutly used it for a spacer in the bulkhead tabbing. We're currently using half inch Divincycell foam. It's works fine other than it needs to be cut and scored into hundreds of little squares in order to achieve the hull shape. Is there a quicker or easier product or way. Thanx.
GreenFlash35
Building Our Sailboat Michelle Potter Buying a Boat Articles 0 04-22-2004 08:00 PM
Building Our Sailboat Michelle Potter Gear and Maintenance Articles 0 04-22-2004 08:00 PM
replacing bulkhead sneuman Gear & Maintenance 3 06-03-2003 03:24 AM
Building Moondancer Michelle Potter Buying a Boat Articles 0 08-26-2000 08:00 PM
Building Moondancer Michelle Potter Gear and Maintenance Articles 0 08-26-2000 08:00 PM
