  #151 (permalink)
Old 12-18-2010
Mike Gunning
mgunning is on a distinguished road
Been reading this blog and am puzzled. As a owner of several boats including an Ericson with a 23hp diesel, I have not been impressed by the ICE being the answer to get me where I want to go and back home. The systems are complex (starting, cooling, gear, fuel, and electrical) and need constant attention and that is with a newer motor.
I have just purchased a Newport 30 and will be repowering it with electric. I would like to check out Cool's Islander 30 as it would be a comparable boat. I am going with the Electric Yacht 180i, 48v, 8 Trojan 125s and a backup generator with solar and wind generators later. We have scoped the system for a 30 mile range at 4.5k. It is primarily a sailboat so I am not too concerned about the range. The issue I am trying become clear on is the best prop as the electric is so much more effecient at driving the prop, especially at low rpms, and its ability to regenerate.
I am in Dana Point. If you would like to show me your Islander, you can email me at mikegunning47@gmail.com.
  #152 (permalink)
Old 12-18-2010
Mark F is on a distinguished road
Hi Mike,
Sounds like a good setup. It's interesting watching the industry become standardized. Electric Yacht is a good company with very good customer service. I bought a competitors product but have communicated with Scott and Bill at EY over the years and they have always been knowledgeable and helpful.
  #153 (permalink)
Old 01-04-2011
engele's Avatar
engele is an unknown quantity at this point
Originally Posted by COOL View Post
Your posts in this thread have all been far too reasonable.
Thank you Cool. Sometimes I think my opinions are unwanted on this forum. People get way too worked up about this stuff when really it doesn't matter that much.
  #154 (permalink)
Old 01-16-2011
Jimske is on a distinguished road
Interesting thread. Lots of good ideas. The installation must accomplish the need and if it does that then it is a success. I am thinking of putting a spin bicycle in the cockpit and using that to turn the prop. My wife spins so . . . Problem is I don't have a prop so I am going to start there.
What I want is to keep my 9.9 outboard which generates 12v for my single battery. My problem is the outboard, which is situated on a "sled" between the port ama and main hull on my SR 31 A Frame. Works fine much of the time but when I need a little more power for problem currents or headwinds when I don't feel like tacking all day to get home. It would be real nice to have 3 or 4 hours worth of "boost." And I guess that a prop deeper then my outboard prop would be better. Motor sail? Why not? Even though the SR31 will do half the wind even 8-10kn wind.
One of the many great things about this boat is storage and access to it.
What I want is to be able to use the outboard in conjunction for the most part and use a 12v electric motor attached to a shaft and prop which I need to figure the angle and size and placement. I might use the electric motor for a few hours on it's own.
I got a funny feeling from reading all these posts that 12volts ain't gonna make it! Too bad because I thought the outboard and a 12v wind generator could help charge the batteries.
Green? It'd be nice but I don't care! My truck gets 15 mpg, my house uses oil and is not that energy efficient. I would even consider running a small electric motor off of an easily removable gas generator push comes to shove.
Money? I don't have any but my wife says that doesn't matter and I should be able to get anything I want because I want it. ;-)
Any positive comments (read no bad vibes please) will be VERY welcome.
Thanks in advance.
Jim in CT now.
  #155 (permalink)
Old 01-31-2011
Mike Gunning
Well, I just installed my new electric system in my 79 Newport 30. It took towoof us to do it and it went quickly. Today, after our first test runs, we are now forecasting a bit better distance on a full charge. We went with a bit bigger battery package, 8 6v 300AH AGM's from lifeline, not cheap. Since I have two new 12v batteries for the house system, I am planning on getting two additional inexpensive 12v to produce a second 48v system with a stepdown to drive the 12v house systems (lots of blender power).
I am also looking at solar and a wind generator. Finally there will likely be a 2000w generator that will share the propane system that I will use of the BBQ and galley cooking.
I will let you know how it goes.
Mike
  #156 (permalink)
Old 01-31-2011
centaursailor's Avatar
Senior in age only!!!
centaursailor is on a distinguished road
Read some of this thread and reckon its about were electric cars were 10 years ago.
The technology is there already but the cost/benifit is still prohibitive.
The traditional ICE supporters tend to be reluctant to come on board but nothing new there.
A few articles have appeared on electric sail boat motors and the results are positive, most of them have either a gen set or a fuel cell as back up. The fuel cell is more efficient but currently very expensive. Some fuel cells have been developed to use propane/butane, tho not ideal the fuel, is readily available.
In a sail boat with the ability to charge from wind, drag and solar and with the reliability of the electric motor its only a matter of time before the iron main will be purring like a ***** cat.
Opps,seems I have offended big brother with that annology
The great appear great because you are on your knees. James Larkin, Irish Labour Movement.
  #157 (permalink)
Old 01-31-2011
P35juniper is on a distinguished road
Mgunning, Be carefull keeping those Lifeline AMGs happy, What do you have for a dockside charger? any thoughts on a 48vdc genny? I take it you are planning to have the house bank as a back-up. Keep us updated on good, bad, and different, mustly the different.
The Joys and Pitfalls of Buying a New Boat - Part 1 Lin & Larry Pardey Buying a Boat Articles 6 10-24-2010 04:49 PM
The Basics of Reefing Mark Matthews Seamanship Articles 0 03-29-2004 07:00 PM
Sailing Basics Steve Colgate Seamanship Articles 0 03-09-2003 07:00 PM
Sailing Basics Steve Colgate Her Sailnet Articles 0 03-09-2003 07:00 PM
Sail Trim Steve Colgate Learning to Sail Articles 0 05-10-2000 08:00 PM
