Old 11-07-2009
nskinn is on a distinguished road
Broken Rudder Head
Does anybody have a rudder head that they don't need anymore? I would like to buy one that will fit a 3/4 inch rudder shaft.
Here are a few photos of my broken rudder head:
http://imgur.com/cBdEV.jpg
http://imgur.com/jcY0x.jpg
http://imgur.com/Z3FWQ.jpg
http://imgur.com/NnxEK.jpg
Old 11-07-2009
merc2dogs is on a distinguished road
May have one in the garage, I'll have to measure it though.
Was in a bunch of 'junk' I received in a trade.
Any idea why the old one failed? They are normally pretty durable, wearing out is rare, but actually breaking is a new one on me. Wasn't mounted 'backwards' was it?
Ken.
Old 11-07-2009
I'm not sure why it broke. I just bought the sailboat about 2 weeks ago. It's my first boat.
That would be great if you have one that fits!
Old 11-07-2009
Given his photo, it does look like it was mounted in reverse and used with all the load on the bolt alone, rather than on the sides of the rudder post cap...
Old 11-08-2009
I have seen a couple of other sailboats with the rudder head installed backwards.
Did some sailboat manufacturers install them backwards or do the owners or mechanics accidentally do it?
Old 11-08-2009
xsboats's Avatar
xsboats is on a distinguished road
The rudder head is usually mounted in accordance with the keyway on the shaft. The keyway on the rudder head is usually on the solid side as opposed to the split side of the rudder head. It could be that the rudder head had been replaced by a previous owner with one that was configured differently. Spartan manufactures rudder heads which are available from RigRite. Be prepared to drop $$$$ for them , as they are very proud of their product.
Old 11-10-2009
Sorry, finally managed to dig them out, both of them are for one inch shafts, so looks like you need to keep looking.
Ken.
Old 11-10-2009
Just thought, If you know anyone with a MIG welder, you can bet silicon bronze wire for them. Needs to be MIG (with gas) not just a 'wire welder'
Have them 'build' a new ear with new weld, then file and drill.
It's a fairly common procedure in metal repairs, just keep building on the bead till you have sufficient thickness for the part you need.
I've actually built 'castings' using nothing but weld and a washer to start with.
Ken.
Building a Rudder Newport 30 Armchairprotest Gear & Maintenance 5 04-07-2009 01:11 PM
Emergency Steering John Kretschmer Seamanship Articles 0 03-08-2002 07:00 PM
Emergency Steering John Kretschmer Gear and Maintenance Articles 0 03-08-2002 07:00 PM
Emergency Steering John Kretschmer Cruising Articles 0 03-08-2002 07:00 PM
