11-09-2009
It would help if you said what kind of boat this is on, and whether the boat was painted or not. If the blisters are dry inside, then it is likely that they are not OSMOTIC blisters, but most likely due to some contamination of the gelcoat during the layup process.
Unfortunately, fixing them is going to require sanding them open, filling and re-fairing the area with thickened epoxy and re-gelcoating or painting the area.
