Electrical draw of autopilots? - Page 3 - SailNet Community
Blogs
  #21 (permalink)
Old 11-11-2009
Originally Posted by mitiempo View Post
....He's sailing to Panama, through the South Pacific and to Australia....
Sounds like wind vane territory to me... which ever you choose you'll have plenty of time to tune it up...
1984 Fast/Nicholson 345
  #22 (permalink)
Old 11-11-2009
Building your own windvane or using a sheet-to-tiller steering setup isn't a bad idea, and not very expensive....for a smaller sailboat it is quite feasible.
  #23 (permalink)
Old 11-12-2009
roline's Avatar
Cal 9.2 SilverSwan
roline is on a distinguished road
I ended up with three Raymarine units, 800, 1000 and st2000+. Power drain would depend on the sensitivity setting on the unit and the conditions. The 1000 is more docile than the 2000+, but I prefer the 2000+ being connected to seatalk and remote controlled with a st6001 head. It also can be controlled by the chartplotter. Windvane would be the cruisers choice if at all possible with an autohelm as backup. Having to tend helm for many hours can be done, but you still need a little sleep now and then.
Cal 9.2 #19 SilverSwan
  #24 (permalink)
Old 11-12-2009
GaryHLucas is on a distinguished road
Another thought for you. Autopilots of any kind use a lot of power because they have to push as hard as you do to steer. However, if you rigged a trim tab on your rudder and used the tiller pilot to drive that you could radically reduce the power requirements. Brent Swain shows how to do this on his steel boats.
Gary H. Lucas
Calculating Your Electrical Load Kevin Jeffrey Gear and Maintenance Articles 0 03-03-2003 08:00 PM
Electrical Power on Board Kevin Jeffrey Gear and Maintenance Articles 0 02-11-2003 08:00 PM
Electrical Power on Board Kevin Jeffrey Her Sailnet Articles 0 02-11-2003 08:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
