11-10-2009
I would be hesitant to use that stuff on the hull deck joint for several reasons. First, I don't know how elastic it is. Second, the bond strength is far too high, and will become a problem if you need to disassemble the hull deck join for repair in the future. It is significantly stronger than the gelcoat to fiberglass bond IIRC. Third, I don't know if the material has a long enough working time to be really usable in this application.
Given that your hull deck joint is through bolted every 3 inches with 1/4" bolts, you may not really require an adhesive sealant for the joint and might be able to use a much more user friendly sealant, like butyl tape instead of a polyurethane-based adhesive sealant, like 4200 or 5200.
