To torque or not to torque - Page 2 - SailNet Community
Blogs
  #11 (permalink)
Old 11-12-2009
roline's Avatar
Cal 9.2 SilverSwan
roline is on a distinguished road
Cal 9.2 keel bolts
I had bought a used Cal 9.2, with a cast iron keel. Several months after having it delivered, a couple of the keel bolts weeped a little. So in my infinite wisdom, I applied a torque wrench only to find one the bolts to spin and not get tighter. The other ones tightened with only a partial turn. I was horrified that the threads had stripped in the cast iron and it would have to be pulled out. I proceeded to only make things worse and ended up pulling the boat. Searching the INTERNET, the Cal has side pockets for the stud ends to be topped, er bottomed off with a washer and nut, just like in the bilge. The studs were solid rod with the ends threaded. The studs were pristine in condition (fresh water boat) steel studs and iron keel, little potential difference. For more on this project check out the link below...
keelbolts
Cal 9.2 #19 SilverSwan
  #12 (permalink)
Old 11-12-2009
davidpm's Avatar
davidpm is on a distinguished road
Based on what mintkake and the Catalina tech said the following is going to be my recommendation unless we get some veto's or modifications from SD, MS et al.
  • Properly block boat on land then do the following one nut at at a time not all at once:
  • Mark nut position, take picture
  • Remove nut and clean and lube thread.
  • Replace nut and torque to 80 lbs.
  • Check nut position, take picture
Results:
  1. If nut twists the bolt off, be glad it happed on land not in the water, Fix boat.
  2. If you can not get nut to hold torque, fix boat.
  3. If nut distorts floor of sump, fix boat.
  4. If nut turns just a little further than last position mark position and take picture. If this happens next season, fix boat.
  5. If nut torques to old position, smile.
Interpretation of results:
  1. Bolts breaking off is usually a sign that service is needed.
  2. Anything other than the nut torquing to original position means something is going on and needs to be dealt with.
  3. If the nut torques to original position it is a good sign but not a guarantee of a sound keel boat. Check the keel-hull joint for signs of weeping.
If you have a Catalina from 1988 or before be especially vigilant as they put plywood in the sump that rots out has has to be replaced. Other builders did the same.
  #13 (permalink)
Old 11-12-2009
David—
If the bolts haven't been inspected in a while, say five-to-ten years, it would probably be much wiser to drop and rebed the keel, and inspect the full length of the keel bolts in the process.
  #14 (permalink)
Old 11-13-2009
Stillraining's Avatar
Handsome devil
Stillraining is a jewel in the rough Stillraining is a jewel in the rough Stillraining is a jewel in the rough
I for one like the idea of bolts threaded into cast Iron..
I just asked Gene Gammon how Irwin built their keels he said they used "j" bolts molded in the keel at the pore..there is no way to remove them for inspection
I have 14 of them...half of them under the main engine and the gen set...all 1 1/8" SS ...I'm not looking forward to dropping the keel ever...but also would love to have the piece of mind things are as should be...if there was ever a place for silicon bronze it was here.
To me 80 fp torque sounds way to light for a 3/4" studs..but they are the experts...shoot my Perkins 5/8" crank pulley went 120 fp.
"Go Simple...Go Large"
Relationships are everything to me..everything else in life are just tools to enhance them.
The purchase price of a boat is just the admittance fee to the dance...you still have to spend money on the girl...so court one with something going for her with pleasing and desirable character traits others desire as well... or you could find yourself in a disillusioned relationship contemplating an expensive divorce.
  #15 (permalink)
Old 11-13-2009
denby's Avatar
Location: Dead Sea, some times called Long Island Sound
denby is a jewel in the rough denby is a jewel in the rough denby is a jewel in the rough denby is a jewel in the rough
David—
Dave, Dawg is really good at this.
Dawg, I'll call you with new info.
Dennis
O'Day 302
Be careful or i will do what the voices tell me to do
To get the most from Sailnet, follow the link in
's signature.
Hey stuffit "Get a life"
  #16 (permalink)
Old 11-13-2009
bubb2 has a spectacular aura about bubb2 has a spectacular aura about bubb2 has a spectacular aura about
Rain, a while back The Beneteau dealer that I bought our boat from send me a email about service specials. Among them was re-torquing the keel bolts to 85 pounds. I thought the same thing that does not sound like enough, but then i was thinking much more and you could be crushing fiberglass between the keel and the washer.
I did send them back a email and said thanks for the spec. but I will do this one myself. This fall they did not list the 85 pound spec in their fall service specials.
Never Forgotten
  #17 (permalink)
Old 11-13-2009
tommays's Avatar
tommays is on a distinguished road
Guys your having a delusion If you think YOUR uncalibrated Torque Wrench is going to turn a nut to same place as the factorys uncalibrated Torque Wrench
Just the type of lube alone can have a massive effect on how far a nut spins at Torque
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
  #18 (permalink)
Old 11-14-2009
Shortman is on a distinguished road
Am I understanding this
correctly that the Catalina keel bolts are lag bolts? Lagged into wood or lead?
  #19 (permalink)
Old 11-14-2009
Omatako's Avatar
Omatako will become famous soon enough
Actually, I can't torque the keel bolts on my boat, I can't find them
Oh and SD, a common failure in keels (as we have debated before about Moquini) is bad construction. This is how one of my earlier boats ended up and all the keel bolts were all beautifully tight.
I speak with some practical authority on this particular subject. This is why the built-in keel is now a non-negotiable for any boat I own.
Arthur C. Clarke
  #20 (permalink)
Old 11-15-2009
ChuckA's Avatar
ChuckA is on a distinguished road
Roline, That's a helpful webpage with details of your keelbolt refurb!
Getting back to the original question, "should a keel bolt torque check be part of a survey?" It seems like checking the torque may reveal a gross problem like a stripped thread, helping to avoid some surprises, but won't reveal all possible issues.
I switched my icon because I took ownership of a Pearson 28-1 yesterday!
Best,
ChuckA
Twitter: @CoastalCafe_NE
Yanmar 2GM20 F Exhaust Riser bolt Torque specs ronsunni Diesel Engine Forum 0 10-08-2009 02:59 PM
Valiant 42 Diesel capecodphyllis Boat Review and Purchase Forum 31 12-19-2006 03:50 AM
Keel Bolt Torque GordMay Gear & Maintenance 2 05-07-2003 10:34 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
