Old 11-12-2009
charisma94 is on a distinguished road
I put a little bit of petrol in my fresh water tank...
We lent our boat to my brother... while doing the right thing a gassing the boat up after using, he put maybe a gallon of petrol in our fresh water tank. After removing liquid and washing inside of the tank with detergent & then flushing out... Any tips on cleaning so we wont get the pertol taste???
Old 11-12-2009
knothead's Avatar
If you have an access plate, I would suggest that after you do what you suggest above, you then drain and dry the tank. Then crumple up balls of newspaper and fill the tank through the access hole. Close it up for a month or more and then remove the newspaper balls.
Rinse it out and fill it up. You should be good to go.
This really does work. I once restored a plastic ice chest that some fish was left to rot in. It was horrible. After the newspaper thing, there was absolutely no smell.
But if you need to use the tank next week, you may have to just wash it and rinse it repeatedly until the smell is gone.
Ron Paul 2012
"wikijar"
Old 11-12-2009
JProcter is on a distinguished road
Use anhydrous isopropyl alcohol, a couple of consumer sized bottles. Widely available, cheap and has great solubility (oretty close to miscible) for diesel and water.
Old 11-12-2009
pdqaltair's Avatar
pdqaltair is on a distinguished road
ventilate ALL winter.
A friend of mine did that last year. I addition to some of the above steps, which all helped, he left an aquarium air pump running for months. That did it. Of course, he had a trailer boat. That would not be permitted at most land storage areas if you need to plug-in to run it. Something solar powered?
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
Old 11-12-2009
if you do this, flush the system well, as isopropyl alcohol is toxic. using several bottles of cheap vodka might be a better, wiser, safer solution.
OI 41 Owners - Water tank help! kcarreiro Morgan 1 11-03-2009 03:32 AM
St. Maartin, St. Barts & Anguilla bbayer4230 Chartering 2 04-23-2006 06:04 PM
'68 M34 Water Tank Fill Hose Question dancrosswis Morgan 0 04-01-2006 02:07 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
fresh water tank maintenance wrguest Gear & Maintenance 1 01-07-2002 11:37 AM
