-   -   Jack Line - Home Made? (http://www.sailnet.com/forums/gear-maintenance/59786-jack-line-home-made.html)
GMC 11-13-2009 03:06 PM
Wonder if I'm missing something. Rather than paying over one hundred fifty dollars for webbing jack lines, can't I just buy 1 ", type 18 webbing and and make my own? If so and my intent is to run one up both sides and clip lines to base of cleat and then run back to tie off/adjust on stern cleats, what type of clip/biner suggested for one end of each line. I don't want them sewn together at bow point. .58 cents a foot on the webbing looks pretty good.
tommays 11-13-2009 03:14 PM
WELL
Its a life and death tool i would want to be sure the bargin was not going to die from UV in two weeks
We just tie off the ends on stern cleats
GMC 11-13-2009 03:19 PM
Yes, I would tie off to stern as well. The U/V thing is interesting as I've found nothing to suggest that the webbing is treated any differently for off the shelf jack lines from marine supply sources. That is, I think (and wonder) if it is just basic 1 ", type 18 with heavy duty clip and sewing already done. Actually the price I just saw was for 250.00 for a set.
cruisingdream 11-13-2009 03:34 PM
Don't use stern cleats, aft jack lines should be tied off about 6 feet (length of tether)from the stern thus you aren't being draged behind the boat. unless you are bait!
jbarros 11-13-2009 03:35 PM
I trust my life regularly to off the shelf webbing while climbing. Lets err on the side of caution and say it does suffer from UV exposure, and you're going to want to replace it once a year, or even twice? I pay about 30c a foot for 18kn rated webbing, and it takes all of, what, 5 minutes to rig them if you have the tie off points/cleats installed? Sounds like a win to me.
disclaimer: I am not a rigger, nor do I have any professional expertise with boats or life saving devices.
-- James
rikhall 11-13-2009 05:18 PM
On ours we have an "eye" sewn at the bow end that goes under and then over the cleat centered just aft of the bow. We then go back to cleats about seven feet from the stern and tie them off there.
Two questions:
1 - are you willing to trust your life to the webbing (my answer is yes)
2 - are you willing to trust your life to your sewing of the "eye" - again, my answer is yes.
And for that price - I can replace them just about as often I we want. And, I bet I could lift a truck with the webbing. - but that is just a guess.
UV degradation?? Ours are inside the cabin unless rigged. In most cases they don't get rigged because in most cases we stay put if we are going to need jack lines. Always rigged and used for night sailing and we have found that there is not a lot of UV degradation to the jack lines at night.
Cheers
Rik
pdqaltair 11-13-2009 05:31 PM
Sounds good to me...
Are you a climber; it sounds like you might be. If you are talking about tubular climbing webbing, sure it's strong enough. I actually use 5/8" dock line, but I have a cat and they are not rigged where they are underfoot. But the nice thing about dock line is that I can leave them set for years; always available at night, when on deck alone, and in storms.
The comments on UV are correct. Climbers see anchor slings in the mountains all the time that are destroyed by the sun.
I have a long posting on my blog about jacklines and such. Perhaps it will give you ideas. Sail Delmarva: Search results for climber
Background: I am an engineer and a rock climber /mountaineer with 25 years experience in all sorts of places.
pdqaltair 11-13-2009 05:35 PM
I like that!
Cheers
Rik
Actually, the same is generally true of all gray weather.
sailingdog 11-13-2009 08:16 PM
I'd point out that the best jacklines are probably 1/4" or 5/16" spectra core-line with tubular webbing over it... the webbing acts as chafe and UV protection and also serves to make the jacklines easily identifiable under any conditions. THe webbing also makes it less likely to roll underfoot.
CrazyRu 11-13-2009 09:37 PM
Yeah, over $2 per foot v.s. $.30 per foot with same result and same strength.
What's the point?
