Truth in Labeling for 2010!
After last years posts on this and other forums, a post on my blog (above), and a bunch of e-mails to state regulators working the antifreeze beat, perhaps there was an effect. Certainly, there is a change. I was walking a boat store the other day and noticed that all of the AF bottles now have labels that clearly state the glycol content and the freeze/burst ratings.
Wow.
http://mystarbrite.com/public/pdf/St...Antifreeze.pdf
This, from West Marine:
"West Marine Pure Oceans -50° (-46°C) Marine Antifreeze provides the ultimate in cold weather and corrosion protection for drinking water systems and all engines. Its premium additive package prevents corrosion of aluminum, copper, brass and solder, but will not harm rubber, seals or hose materials. The 3X-died bright pink color provides excellent blow-through visibility. Formulated with non-toxic, virgin Propylene Glycol (30% Blend), it is tasteless and contains no alcohol. This product is ready-to-use; do not dilute it.
Provides burst protection to -50°F (-46°C) and freeze protection within a range of +12°F to +16°F (-11°C to -9°C)
When testing with a refractometer or hydrometer designed for use with propylene glycol, freeze point readings on the PG scale will range from +12°F to +16°F
Note: The burst point of PVC pipes used in most drinking water systems is about -10°F (-23°C). When winterizing water systems in regions where temperatures can fall below -10°F (-23°C), we recommend using West Marine Pure Oceans -100°F (-73°C) Marine Antifreeze."
Granted, that in the correct circumstance, -50F burst protection is possible, but there are exceptions:
* Ice will begin to form at +16F and it won't circulate. Just so you know.
* PVC will burst at -10F.
* Both PVC and copper pipe will burst before that, because the model assumes that the the item is sealed and has been contracting from room temperature; if it refilled by drainage from higher areas, then the burst comes sooner. Second, the ice and water will separate during the winter, the ice will float, and high areas of plumbing will be vulnerable to bursting well above zero. This is a risk in complex piping, engines, and tankless water heaters if the temperature cycles below +16 F many times.
The bottles now have a nice chart showing the freeze point, the slush range, the burst point, the dilution, and they do state the amount of glycol, so this is all an improvment.
But I would still be wary of cutting it too thin. They are right; dilution is a no-no, because there may not be much glycol to start with! The information is right on the bottle.
