11-14-2009
No real need to flake the sail, if all you're doing is replacing the halyard and putting it back on the furling unit. I would point out that you really should stitch and tape the old halyard to the new one for when you're pulling the line through the mast. To do this, butt the two lines up against each other and then sew through both with whipping twine and a sail needle in at least two directions, then tape over the join to smooth it and protect the stitches. This will minimize the chance of the two separating during the pull.
