Old 11-16-2009
gatosolo's Avatar
gatosolo is on a distinguished road
Rain water getting into the cabin
Hi,
I have a 1978 Columbia 8.7. I just found this weekend that rain is getting in on the port side of the cabin. The port cushion was wet as was the ceiling below the portholes. There was some water damage on the sole. (It had been raining for a week.
I was wondering if this is something that other Columbia 8.7 owners have experienced. I am planning to take down the teak paneling to look at the porthole seams. Any other thoughts?
Thanks,
Victor
Old 11-16-2009
QuickMick's Avatar
QuickMick is on a distinguished road
short term fix
butyl tape (found at rv stores) was suggested to me here for short term fix until im ready to rebed. i used it on the outside of a couple of minor leaks in ports and been bone dry ever since. looks to be much eaiser for removal than silicon alternatives.... while its not a perm. fix, it is holding up well in the interm.
Quinn
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 11-16-2009
gatosolo's Avatar
Thanks!
Old 11-16-2009
Vasco's Avatar
Warm Weather Sailor
Vasco is on a distinguished road
The hardest part will be determining where the water is coming in. Once you find that out, and it might take a bit of time, fixing it should be relatively easy. It might be the ports, it might be hardware attachment points on the coach roof, toe rails or a myriad of other things.
Rick I
Toronto in summer, Bahamas in winter.
Old 11-16-2009
tommays's Avatar
I dont know if it works BUT it was said IF you can seal up the boat and blow into it with a shop-vac and then use some soapy water the leaks should bubble ?
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 11-16-2009
QuickMick's Avatar
oh
oh, before i started tearing into stuff for examination, i just spent the day on the boat when it was due to rain. while i know water can run a long way from a leak before becoming visible, in my case this greatly expidited the location of the water. heck, you could probably do the same thing with a couple buckets of water....
Q
Quinn McColly
Yacht Broker
Old 11-16-2009
GaryHLucas is on a distinguished road
I plan on using a blower to find leaks in my deck. However I'm going to use an electric leaf blower as it produces a lot more air at a lower pressure.
Gary H. Lucas
Old 11-16-2009
Bene505's Avatar
Glad I found Sailnet
Bene505 will become famous soon enough Bene505 will become famous soon enough
Gary H. Lucas
If you have a removable speed or depth transducer, you could take it out and use the hole as the opening for the leaf blower. That way, you can latch everything else down tight. Stuff some wet t-shirts around your hatch boards as you slide them in, to help seal that better.
At least, that's what I'm planning, since I have a couple driping spots to take care of.
Regards,
Brad
Old 11-16-2009
tager's Avatar
tager is on a distinguished road
If you have ever read tortilla flat, you may know the solution. "It's okay I didn't like that part of the boat anyway."
Old 11-23-2009
gatosolo's Avatar
I found the leak! I took off the wood panel (which only required to be unscrewed). The water stain was obvious at the aft port portlight. I took it apart and recaulked it.
Thanks for the suggestions.
Gifts from the Rain Gods Doreen Gounard Cruising Articles 0 03-18-2004 07:00 PM
Gifts from the Rain Gods Doreen Gounard Her Sailnet Articles 0 03-18-2004 07:00 PM
