  #21 (permalink)
Old 11-20-2009
I'd point out that vinegar or acetic acid will remove the barnacle bits...without damaging the metal.
Polishing the surfaces makes it more difficult for the underwater growth to adhere...but coating it with something like vaseline or such will help prevent growth as well...
  #22 (permalink)
Old 11-20-2009
Bene505's Avatar
Glad I found Sailnet
Bene505 will become famous soon enough Bene505 will become famous soon enough
Coating your shaft with vaseline -- never hard of that.
I heard something about covering your prop with a sharpie's indellible ink. Didn't try it though.
Anyone want to get 3 products and use a different one on each prop blade? tehn we would really have a very controlled study to see what works.
Regards,
Brad
  #23 (permalink)
Old 11-20-2009
T37Chef's Avatar
Senior Culinary Member
T37Chef will become famous soon enough
The vaseline works, for a while. I use it on my speedo wheel
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
THE Yacht Builders List:
Useful Food Purchasing Links:
  #24 (permalink)
Old 11-20-2009
mgmhead's Avatar
Somewhat Senior Member
mgmhead is on a distinguished road
The Petit spray has been the best I've found. In the Chesapeake from
April till November and only cleaned once in August, in the water and scraped by hand. This was the second year I've used it and I found that several coats (3 or 4) gave better results than the two coats applied the previous year. Maybe 2009 was a milder year for barnicles in Rock Hall, but I don't think so. Anyhow, next spring I'll be applying six coats of Petit Zinc Spray.
s/v Rhythm
Catalina 387 #29
Rock Hall, MD
  #25 (permalink)
Old 11-20-2009
pegasus1457's Avatar
Arf!
pegasus1457 is on a distinguished road
The Pettit instructions warn you not to apply more than 2 coats or risk wrinkling and peeling. Don't get carried away
Fluctuat nec mergitur
  #26 (permalink)
Old 11-20-2009
ChuckA's Avatar
ChuckA is on a distinguished road
ChuckA wrote> I since learned that the nuts are on backwards in this picture. The thin nut is supposed to go against the prop with the thicker nut on the end of the shaft. It ran like that for a couple of seasons after which I reversed them. Don't think it made any real difference.
BELLATRIX1965 wrote > ChuckA - you had the prop shaft nuts on CORRECTLY in your photo - the thick nut should be next to the prop - its numerous threads take up the axial load of "pushing" the prop onto the shaft taper - the thin nut is only a jam locking device to keep the whole mess from un-screwing (just in case anybody else looks at this thread!).
That's what I used to think too, but I've been told otherwise by people with more knowledge and experience than me. The image below is from the installation instructions on the Michigan Wheel website it clearly shows the thin nut going on the shaft first, followed by the thicker nut.
Here is a link to installation instructions on the Tacoma propeller website, a dealer of Michigan (and other) props. It specifically states:
Correct Nut Instaltation Procedure: Install Jam Nut (thin) first than the Full nut (thick) goes on second.
my parting comment: on the cruisers & Sailing forum GreatKetch wrote>
At least you didn't ask which nut goes on first the big one or the little one. That ALWAYS starts a fight.
I'm not sure why. I think it has to do with most of the load is taken up in the first 1.5 threads. The flexibility (thinness) of the nut affects the load distribution as well.
I'm a lover, not a fighter, so I'll let it drop at that.
Cheers,
Chuck
Best,
ChuckA
Twitter: @CoastalCafe_NE
  #27 (permalink)
Old 11-22-2009
T37Chef's Avatar
Chuck...FYI, time for a new thread I think
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
  #28 (permalink)
Old 11-23-2009
saildog1 is on a distinguished road
I also use the Petit Zinc spray and it works pretty good. Do a couple coats and the prop and shaft should stay clean. Don't spray the zincs.
LUNA
Tartan 3800 #3
  #29 (permalink)
Old 12-06-2009
GaryHLucas is on a distinguished road
The prop nut debate is interesting. A couple months ago I got a copy of Professional BoatBuilder and they had an extensive article on it. It seems there is an ABYC standard on it, and the thin nut goes against the prop! The reason makes sense. When you tighten the outer nut it it unloads the threads on the inner nut. So you want the outer nut thicker to carry the load, and the inner nut locks it by friction.
Gary H. Lucas
  #30 (permalink)
Old 12-06-2009
chef2sail's Avatar
C&C Racer/ Cruiser
chef2sail is on a distinguished road
I am in the same creek as t37chef. Like him I use the petit spray and am amazed with the results. When swimming in the summer I put the snorkel on and do a few dives and use a green pad to take of any critters who want to nest..
Dave
___________________________
S/V Haleakula (Hawaiian for" House of the Sun")
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
prop shaft assy pmcandrew Gear & Maintenance 1 01-23-2005 04:41 PM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
Drive Train Vibration Tom Wood Gear and Maintenance Articles 0 10-10-2002 08:00 PM
prop shaft thomasstone Gear & Maintenance 3 03-27-2002 03:03 PM
prop shaft coupler thurston Gear & Maintenance 2 12-31-2001 06:00 AM
