barnacles on prop, shaft - Page 5 - SailNet Community
 4Likes
post #41 of 54 Old 07-19-2013
JimsCAL's Avatar
Re: barnacles on prop, shaft
After being away for 2 weeks, I spent an hour in the water cleaning the prop and bottom yesterday. Bottom only had some slime (I used Pettit Horizons) but prop and shaft had lots of small barnacles (used Pettit Zinc Coat). Pretty much the same as in previous years here in Western Long Island Sound.
JimsCAL is offline
post #42 of 54 Old 07-19-2013
Learning the HARD way...
eherlihy's Avatar
Two years ago (2011) I had the bottom of my O'day 35 soda-blasted, barrier coated, and had three coats of Pettit Horizons applied (initial coat of red, and two of blue). So far, the paint has held up VERY well, and still seems to be doing it's job. I dove on the boat this week, and brushed off heavy slime, but no barnacles.
The prop and shaft, were a different story. I had applied two coats of Pettit Transducer paint (mentioned earlier in this thread) in the spring. The prop and shaft were completely covered with little barnacles. They scraped off easily with a putty knife, but the little buggers seem to have adapted to the zinc based paint.
This was instigated after I noticed diesel smell, and black exhaust (soot) while motoring, and that she would only reach 2100 RPM at WOT. After the brushing and scraping, the motor would run at 2800 RPM at WOT, and speed (motoring) increased from 4.9 to 6.0 KTS.
She's not perfectly clean, but she is a good deal cleaner than she was.
eherlihy is online now
post #43 of 54 Old 07-19-2013
blutoyz's Avatar
-1 for the Pettit spray
I had to scrape my prop after 1.5 months in the water, it was covered with barnacles
blutoyz is offline
post #44 of 54 Old 07-19-2013
chucklesR's Avatar
After almost 3 years in the water (mid chesapeake) my boat was covered in barnacles and the recent infestation of slime going around on the bay.
I had a diver clean the bottom last week - he said the paid did it's job as the barnacles were not firmly attached (they came off with a light, long stroke of the blade - you could hear him 'whoosh, whosh' scraping away). That's WM's CPP, two coats by the way.
The Max prop and shaft on the other hand were coated. The max prop's blades still rotated, but otherwise they were more paddles than blades. My best speed was 5.0 knts.
I'm looking forward to streaking across the bay this weekend.
chucklesR is offline
post #45 of 54 Old 07-19-2013
T37Chef's Avatar
There's something I don't need to see
jimgo likes this.
Shawn
T37Chef is offline
post #46 of 54 Old 07-19-2013
chucklesR's Avatar
Jealously is so ugly.
At least you'll be looking at my stern
arf145 likes this.
post #47 of 54 Old 07-19-2013
I've been using Propspeed for the last several years, works better than anything else I've ever tried...
However, perhaps this has already been mentioned before or elsewhere, but by far the best solution I've ever found to inhibit growth on running gear of a boat that is sitting, is enclosing it all in a heavy duty black plastic garbage bag, or something similar...
Not convenient for most, I realize, but whenever I know my boat will be sitting for awhile, I put a bag on it... This growth needs some light to flourish, and simply blocking out the light really does seem to do the trick to a significant extent, in my experience...
It's easy to rig the bag with a tagline at the bottom, so that it can be removed without going back in the water... Of course, it goes without saying that if you make this your routine, you definitely want a foolproof 'reminder' tagged to your ignition key, that there's a bag and some light line wrapped around your running gear...:-)
I'm lucky, my prop is quite accessible, I've even been able to get a bag around it without going in the water, using a large fishing net from my floating dock... Of course, those with a prop in an aperture, or a saildrive well forward of the rudder, there's no other option than to dive on it...
Another solution would be to configure a larger form-fitted 'diaper' from a larger tarp, that could led under the boat without going in the water, and be tied off at deck level from each corner... The key would be to make it truly 'form-fitting' to the hull, however, any light getting inside it will defeat its effectiveness to some degree...
JonEisberg is offline
post #48 of 54 Old 07-19-2013
chef2sail's Avatar
This I want to see. A 37 Tartan vs. a 38 Morgan....Both similar PHRF ratings.
I am willing to be the committee boat, since I can sail back and forth between you in our undersized 35 C&C. BTW my money is on Shawn.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #49 of 54 Old 07-19-2013
chef2sail's Avatar
Hoping for 15 knots of wind I see
We are having our bottom done Monday. We have slowed considerably too. Its our third year on Ultima 60 and we coated with the petit stuff on our haul out last summer. I am interested in what the diver finds, as we are still sailing quite fast in the 6+ to 7+ range but under motor barely 5.5
Parkville, Maryland
Our blog-
post #50 of 54 Old 07-19-2013
chucklesR's Avatar
Irwin 38 mk II - not Morgan.
So's my money in a straight up race because I have floppy sails and believe in the 'set them and leave them' trimming school.
Also if he gets there first he can drop anchor and I can raft up to him and save my back/deck from work/mud.
Craigtoo is going to the same place, same time. I actually out PHRF him in his Sabre 34 also. I guarantee I can beat him because he'll be towing a dinghy.
PHRF is for racing, I'm a cruiser. I don't tweak my sail trim every 1.3 seconds on my cruising boat. I relax and enjoy the sail.
Especially, getting back to the original topic - now that the barrier reef has been removed from my hull, prop and shaft.
prop shaft assy pmcandrew Gear & Maintenance 1 01-23-2005 04:41 PM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
Drive Train Vibration Tom Wood Gear and Maintenance Articles 0 10-10-2002 08:00 PM
prop shaft thomasstone Gear & Maintenance 3 03-27-2002 03:03 PM
prop shaft coupler thurston Gear & Maintenance 2 12-31-2001 06:00 AM
