Splicing - Page 2 - SailNet Community
post #11 of 33 Old 11-17-2009
paulk's Avatar
I'd go with pdq on this one. Quick, easy, effective. Sew it shut if you want to be doubly sure it won't come undone. Our spinnaker halyard shackles have had knots for the past 8 years without any problems.
paulk is offline
post #12 of 33 Old 11-18-2009
I am assuming you are looking to just splice in a quick release shackle into the end of your halyards. I used an oldschool book marlinspike sailor a while back to learn to do some splicing. I plan or relearning to do my upcoming projects. I am doing it to because I want to learn and develop a new skill, but for the effort it is probably cheaper to pay someone to do two splices. You should have most of the tools but will need a fid and maybe a pusher, as well as a few hours to learn and do it.
Both Samson and New England rope offer guides online.
Also
Riggers Apprentice by Brion Toss
Or the Marlinspike Sailor
Will be a good sources.
Three strand like you'd use for docking was fairly easy. The double braid is harder. You should probably buy 20 extra feet to practice with before doing your halyards. Make a large eye splice to get a feel for it then make a smaller one before. If it looks right then move on to your halyards.
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
jephotog is offline
post #13 of 33 Old 11-18-2009
snake charmer, cat herder
zeehag's Avatar
ashleys book of knots has how to splice lines..and how to whip them --with and without needle-----
zeehag is offline
post #14 of 33 Old 11-18-2009
STARBOARD!!
KeelHaulin's Avatar
Just be aware that you are cutting the strength of the line by about 50% when you put a knot in it. When use an eye splice you retain over 90% of the original line strength; and usually the eye does not fail unless it was chafed through.
KeelHaulin is offline
post #15 of 33 Old 11-19-2009
Splicing braid is a pain but satisfying and worth it once you get the hang of it. Practice on some expendable rope. Brian Toss has a book and goes over it but the rope makers also have splicing instructons you can download from thier websites. They will also come with the splicing fid you need to buy to do it. No majic here all it takes is time, patience and peservarance.
Waltthesalt is offline
post #16 of 33 Old 11-19-2009
knothead is offline
post #17 of 33 Old 11-19-2009 Thread Starter
QuickMick's Avatar
The Norson Splice
First off, I appreciate the feedback and the general discussion. I went ahead and tried the norson splice. (link below, gleaned from above). I made it to the 2nd to last step, and the 'milking the rope' is a real bear. i wondered if i taped my braid to fat? have any of you tried this splice and encountered a similar problem? it seems pretty straight forward, if you have the time to unsheath the core.... thanks for your help, and maybe this might help you to, as the link has pics that are very good.
How to Eye Splice double braid rope
thanks
Quinn
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Macgregor Venture
QuickMick is offline
post #18 of 33 Old 11-19-2009
It will take you 1hour to master, them you will forget it all in 12hours, if you do it reguirely you will get the hand look a english braids website it gives you all the steps you need. Have fun its very satisfying
whigmaleerie is offline
post #19 of 33 Old 11-19-2009
thanks
Quinn
Check out the video, you may pick up a trick or two that will make it easier.
knothead is offline
post #20 of 33 Old 11-19-2009
SV Djl
braidmike's Avatar
Man, did you hit it on the head!!
I practiced on some inexpensive double braid while on vacation. Started looking pretty good. A few weeks later back on the boat I figured I'd whip out a couple eye splices on some new lines, and then show off to all the neighbors. Frustration beyond belief!! I quietly snuck below, spent a couple days rereading all the instructions, relearning every trick... I now get the instruction sheet out before I start, and reread each step as I go. I guess old brains just don't absorb knowledge quite as quickly.
Good Luck!!
And it is a good feeling when dock neighbors admire your splices!
braidmike is offline
Eye-splicing lines... beatkiddo Seamanship & Navigation 11 09-20-2006 01:28 PM
splicing wire calamityjane Seamanship & Navigation 11 09-13-2004 03:42 AM
chain splicing sailorman10 Gear & Maintenance 7 01-25-2003 02:42 AM
Splicing Chain carisea General Discussion (sailing related) 3 08-21-2002 02:55 PM
Splicing Sta Set X line jsfletch Gear & Maintenance 2 06-25-2001 07:56 AM
