11-20-2009
A simple but effective knot that retains much of the line's strength is the buntline hitch. However, be warned that a buntline hitch does tend to become rather permanent and difficult to untie if its set under load all season.
As for splicing, I second the Toss splicing wands. I would also point out that what line you have will often determine how it can be spliced. Parallel core, high-tech core, or other lines will require a different splice technique from a traditional polyester double braid. Using the wrong splice on a line can be a very, very serious mistake.
