11-19-2009
Old as Dirt!
Just use a couple of pairs of needle nose pliers to grasp the impellor blades, one on either side of the hub, and tug gently. There is nothing holding it in except friction. The earlier suggestion to lube the shaft is wise so long as you do not use a petroleum based lubricant. (Some impellors don't like it.) Glycerin based or silicon based is prefered. You should also lube the inside faces of the pump before mounting the new impellor.
FWIW...
