Mystery Prop Shaft Gland - Page 2 - SailNet Community
Blogs
  #11 (permalink)
Old 11-20-2009
mitiempo's Avatar
Yours doesn't look adjustable except for the amount of grease inside it - strange.
Brian
  #12 (permalink)
Old 11-20-2009
mitiempo's Avatar
Try contacting someone at the Durour Owner's Assoc. Boat Classes
It's a UK group so you don't have to be bilingual
Seems pretty unique all right.
Brian
  #13 (permalink)
Old 11-20-2009
lawsonmitchell is on a distinguished road
Yeah. The only adjustment seems to be pump in more grease? What gives? I'm pulling the boat in February for a bottom job. Maybe I should lose this thing.
  #14 (permalink)
Old 11-20-2009
mitiempo's Avatar
I think I'd replace it with a conventional stuffing box.
Brian
  #15 (permalink)
Old 11-20-2009
erps's Avatar
the pointy end is the bow
Does it leak? I wonder if it's like a "bearing buddy" for trailer wheel bearings. It's a spring loaded grease cup for trailer wheel bearings. I think they work on the principle that there is always some grease pressure on the inside of the hub that keeps the water out.
I belong to the "if it's not broke, don't fix it" club, but if this thing is leaking and adding grease doesn't work, then it probably needs replacing.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 08:00 PM
Drive Train Vibration Tom Wood Gear and Maintenance Articles 0 10-10-2002 09:00 PM
prop shaft thomasstone Gear & Maintenance 3 03-27-2002 04:03 PM
prop shaft coupler thurston Gear & Maintenance 2 12-31-2001 07:00 AM
The Stuffing Box and Stern Tube Tom Wood Gear and Maintenance Articles 0 04-27-1999 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
