Like Tree1Likes
Old 11-21-2009
Bene505's Avatar
Glad I found Sailnet
Bene505 will become famous soon enough Bene505 will become famous soon enough
Hatch lens ccracked in half - best place for replacement?
I just learned the hard way, while rebedding a Lewmer hatch, that getting the hatch to seat correctly by jumping up and down on it is NOT the way to do it.
When rebedding the other hatch last week, I paitently removed all the old silicone from the lens, applied new black silicone and pressed it into place.
This time I though I'd save some steps and rebed over the top of what's already there. Well guess what? The old and the new together made for an increased thickness so the lens wouldn't seat correctly. I tried standing on it. That didn't quick work as much as I wanted it to, so I jumped on it. Well, since it wasn't seated flat with the frame supporting it all the way around, it cracked in half.
So instead of having my 2nd salon hatch sealed and ready for the winter, instead of having great pride in another accomplishment, I have a big hole in the cabin top.
Anyone know where I can get a replacement lens at a reasonable price? I have both pieces of the old lens (now scraped clean) to use as a template if they need one.
Regards,
Brad
Old 11-21-2009
Stillraining's Avatar
Handsome devil
Stillraining is a jewel in the rough Stillraining is a jewel in the rough Stillraining is a jewel in the rough
Try here.
Plexiglass Sheets, Acrylic Sheet, Plastic Displays, Fabrication
"Go Simple...Go Large"
Relationships are everything to me..everything else in life are just tools to enhance them.
The purchase price of a boat is just the admittance fee to the dance...you still have to spend money on the girl...so court one with something going for her with pleasing and desirable character traits others desire as well... or you could find yourself in a disillusioned relationship contemplating an expensive divorce.
Old 11-21-2009
j34035's Avatar
"Sparkie"
j34035 is on a distinguished road
Are these the older ocean series or the newer style hatches. You can contact Select Plastics, they are masters at repairing lewmar ocean series hatches, but making your own is not that difficult. I have a pdf explaining the whole process if you need it.
DD
Doug
Jboat J/37c (new to me Jan 2011)
Old 11-21-2009
j34035's Avatar
"Sparkie"
Refitting hatch lenses
Get a new outlook on life by replacing that crazed, cracked hatch plastic
Waking up and looking through a crazed, hazy deck hatch can be depressing. I can recall quite a few mornings where I thought the day was gray and ugly from the view through the hatch, only to be surprised by a nice day when I came up through the companionway. There is little reason to live with an ugly, leaking hatch and the view that it gives: deck hatch lenses are surprisingly easy
to replace.
Most deck hatches consist of an aluminum (or stainless steel) frame with a plastic lens. The lens is typically held into the frame with a silicone-like sealant. The sealant is typically laid in a wide bead (1/4-inch to 3/8-inch) to firmly hold the lens in place and to allow the lens and frame to expand and contract at different rates.
Over time, the plastic lens will show its age. The first thing to go is the outside top surface—it will get scratched and dinged with everyday wear and tear. The surface can also become damaged from contact with harsh cleaners.
Next, you will start to see internal crazing. The crazing shows up as tiny fractures inside the plastic; these fractures especially show up in the sun. Some of the crazing is from external impacts with winch handles, shackles and the like, but most of it is thermal. Thermal crazing occurs on a hot day with cool water. A dark plastic hatch will heat up to more than 100 degrees on a bright, sunny day. When cool water splashes on the hot hatch it can fracture. Finally, the color of the plastic will start to fade and change from exposure to the sun.
All of that crazing and chipping is not only unsightly—it is also a safety issue. Plastic hatch materials are notch-sensitive. This means that once they are fractured or scratched that damage can more easily grow into a full-fledged crack. That ugly, scratched-up lens could end up collapsing under the weight of a wave crashing on your foredeck.
The types of material for hatch lens replacements are regularly misunderstood. There are really only two types of plastic used, but they are sold under several different trade names. The two materials are acrylic and polycarbonate. Acrylic is sometimes sold under the trade name Plexiglas, and polycarbonate is sold as Lexan. The factors to consider when choosing a material are scratch resistance, chemical resistance, UV life and impact resistance.
Acrylic has better scratch and chemical resistance, and far better UV resistance, but is not as strong as polycarbonate. Polycarbonate wins for absolute strength, but acrylic is a far better material for most boats. Polycarbonate gets its impact resistance from slight flexibility; large, unsupported polycarbonate hatches can sag where acrylic hatches will not. Unless the boat operates in an environment where impacts are likely, you will get far better performance from an acrylic hatch. As an added benefit, acrylic is much less expensive than polycarbonate.
You will not find acrylic or polycarbonate of appropriate thickness at your typical corner hardware store—you will need to visit a plastics supply house. I have had great luck with Midland Plastics, which has several locations across the Midwest. Midland will act as a supplier of bulk plastic or will fabricate your lens using the old one as a pattern.
Both acrylic and polycarbonate are available in different thickness, but strangely they are not typical fractional-inch sizes or metric. The sizes are close to even millimeters, but the material varies a bit in thickness. Your best bet, if you can’t get a perfect fit, is for the material to be a little too thick so that it stands proud of the frame. If it is too thin the lens will puddle water.
The following instructions will take you through the replacement process step-by-step, but if they look too daunting, Select Plastics in Norwalk, Connecticut, or Petaluma, California-based Mariner’s Hardware will do a turnkey hatch refit for you.
Removal
The first step is to remove the old lens, which can be done simply with a utility knife. Just cut around the perimeter of the lens from the top and the bottom. Once the bead of sealant is cut, we can pry the lens out of the frame with a stiff putty knife.
Sealant removal
Removing the residual sealant is the hardest part of this job. All of the residue of the old sealant needs to be removed or the new sealant will not adhere to the frame. I don’t have any magic here; it will take a combination of scraping, wire brushing, sanding and solvents—not to mention lots of elbow grease and determination. Start with a utility knife to get the big chunks off. Next, scrape with a paint scraper. A wire brush with mineral spirits or citrus solvent will get the last of the sealant residue off. Finally, a light sanding will clean things up.
To keep the little of bits of sealant and drips of solvent from getting into the cabin, line the open hatch with a plastic bag, and trap it between the deck and the hatch frame.
Cutting the blank
Next, fabricate the lens. This step will require a router and a flush cutting bit. If you do not have a router or the skills to use one, you can get the lens cut by a plastic fabricator.
Use the old lens as a pattern for the new one. The first step is to remove all of the residual sealant from the old lens by scraping it with a utility knife. A fine film of sealant residue can remain, but you need a smooth surface to use as a template for the new one. Next, trace the outline of the old lens onto the masking paper of the new plastic. To make the router cut easier and cleaner, remove the excess material outside the traced line. Cut within a half-inch outside of the traced line with a saber or band saw.
After the panel is rough cut, adhere the old panel to the new with double-sided tape. The tape will hold the two pieces of plastic together so that you can cut the new panel with the flush cutting bit. A flush cutting bit has a cutting surface and a router bearing. Run the router bearing on the old lens and the cutting surface will cut the new lens to the exact shape of the old lens.
Practice with a scrap piece of plastic before you cut the real blank—acrylic needs a slow steady feed rate so that it will cut smoothly. The router will leave a slightly rough surface on the acrylic, but this “tooth” will help the glue to adhere.
Masking
Like any sealant job, you need to mask off the areas that you don’t want sealant on. Start by masking off the outside surface of the frame, masking right up to the edge. There is really no need to mask the inside of the frame, as you won’t get much squeeze out on the inside.
Next, peel the masking paper off the top of the new lens and mask off an inch or so around the perimeter. The masking tape will be easier to remove than the original masking paper later when gluing the lens in. Peel off all the masking on the back (inside) of the lens. Again, you won’t get much squeeze out on the inside, and if you do, remove it after the sealant dries.
Priming and gluing
There are several sealants that could be used, but I have had the best results with Sikaflex 295-UV. This is a black polyurethane sealant designed as a direct glazing adhesive for acrylic lenses. It hardens to a firm yet flexible flat black, rubber-like material, much like the material used by the manufacturers. The sealant requires a cleaner, Sika-Cleaner 226, and a primer, Sika-Primer 209. The cost of the sealant, plus the cleaner and primer, make it relatively expensive, but you will be happy with the finished result. Sikaflex products can be hard to find, but many large chandleries carry them. If you can’t find them locally, a good mail order source is Jamestown Distributors in Bristol, Rhode Island.
The first step is cleaning the gluing surface on the frame with the cleaner. Just wipe the surface with a rag dipped in 226, turning the cloth often. Once the surface is dry, brush on a thin coat of Sika-Primer 209. This primer looks like a thin black paint, so it will be easy to see where the primer is applied.
Now that the frame is ready, move on to the lens. Similar to the frame, clean the edge and the bottom quarter inch or so of the lens and apply the primer to the edge and bottom of the lens. Be sure not to primer too far out on the bottom of the lens or the black primer will be visible.
I had it in word format. See if this helps.
DD
merv likes this.
Doug
Old 11-21-2009
georgefmys is on a distinguished road
Try Hatchmasters[they are in CT.] However,if you have any marine fabrication shops local to you ,they can do it cheaply[if they want to]. I'm not sure you should tell them about your installation methods. Good luck!
Old 11-21-2009
MikeinLA's Avatar
MikeinLA is on a distinguished road
Just to clarify for the OP, Select Plastics and Hatchmasters are one and the same. Great folks to deal with. The owner, Tony, is a great guy and very helpful.
Mike
Old 11-21-2009
j34035's Avatar
"Sparkie"
I did not know hatchmasters and select were the same people. I will second the word on Tony, he took all the time I needed to learn how to do my own hatches, with him knowing I was not spending money with him. I did buy supplies and gaskets though. Good folks to deal with!!
DD
Doug
Old 11-21-2009
Bene505's Avatar
Now I'm jumping up and down (again) with glee. Thanks for the excellent lead.
For the record, I jumped up and down on the edge that was sticking up about 1/8 inch. One jump actually and not in the center. Still, that was enough. Kicking myself for that one.
Regards,
Brad
Old 12-08-2009
Bene505's Avatar
No go on Hatchmasters
Update: I called Hatchmasters/Select Plastics and they will not sell me a hatch lens. They only do a full refurbishment of the lens.
Seeing how I have it all apart and cleaned already and only need a lens, this is not the way to go for me.
Anyone have any other leads?
Regards,
Brad
Old 12-08-2009
smackdaddy's Avatar
Last Man Standing
Heh-heh. Bene, I love the way you work dude!
I don't know how many times I've done the:
"If I can just....get....this........piece..............in.. ..." [CRACK!].
Then you feel that hot feeling go up your neck. Good times.
I'm glad to know I'm not alone.
BFS Gear: SNers started it....
Resolving Hatch and Portlight Problems Tom Wood Gear and Maintenance Articles 0 03-17-2003 07:00 PM
