Old 11-21-2009
TQA's Avatar
TQA TQA is offline
Bombay Explorer 44
TQA is on a distinguished road
anchor chain question
I want to fit an electric anchor winch and am looking at this one.
Maxwell's all new RC10 series windlasses proudly follow in the highly successful footsteps of the Freedom, Liberty and HRC fully automatic
rope/chain anchor winches.
Features
The all new RC10 fully automatic windlass series is designed to effortlessly retrieve and deploy 8mm (5/16”) and 10mm (3/8”) short link chain and 14mm (9/16”) and 16mm (5/8”) three strand or 8-plait rope
I asked the seller WMJ and they say HIGH TEST CHAIN ONLY I am not sure but I think my chain is BBB so will it fit?? and is there an easy test??
[ No I can not try it on the chainwheel as I am in the USVI and the windlass supplier is in CA.]
Old 11-21-2009
captbillc's Avatar
ancient mariner
captbillc is on a distinguished road
i believe BBB links are shorter than standard links. i would ask the seller if he means BBB chain to be sure your getting the correct windlass. you could look up high test BBB chain & ask the seller why high test only.
Liberals are people who care about others. Freethinkers are not constrained by the myths of religion.
Old 11-21-2009
jrd22's Avatar
Courtney the Dancer
They are different sizes. Here is a link to a dealer, you can get the dimensions and determine what you have.
Chain for the Marine Environment
No association, etc, just found it searching.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 11-21-2009
October Moon B43
MJBrown is on a distinguished road
It appears as though the windlass calls for short link which would be BBB. Check your chain for either "BBB" or "3B" stamped on the links. High test is slightly longer and is marked G4. If the windlass is set up for short link then the longer G4 will likely jump periodically as you drop or weigh anchor. BTW if you do not have a match between your chain and the new windlass you may be able to buy a new gypsy to fit the chain you already have.
Stupid Question krozet Boat Review and Purchase Forum 15 10-11-2009 11:30 AM
Ladder question mcain Gear & Maintenance 14 08-03-2007 10:28 PM
Cruising home/base/marina ICW question thorJ30 General Discussion (sailing related) 3 05-30-2005 05:53 PM
GPS question wallm General Discussion (sailing related) 13 05-30-2004 02:10 AM
question on sails Mark_OD23 General Discussion (sailing related) 6 11-19-2002 04:41 PM
