Old 11-22-2009
voice3 is on a distinguished road
Chrome plated zinc vs. stainless steel
I'm in the process of replacing my locker hinges. My local marine store has Perko chrome plated zinc and Seadog stainless steel hinges. The chrome plated zinc hinges are approximately twice the price of the stainless hinges. I was a bit shocked to see this because I always thought stainless was the best to use for marine applications (except bronze, of course). I must be missing something, can someone fill me it?
Thanks,
Matt
Old 11-22-2009
jrd22's Avatar
Courtney the Dancer
Seems weird to me too that zinc is more expensive. Of course, there are many different grades of stainless. 316 is very resistant to corrosion, 304 less so, and there is just plain awful stainless out there too. See if the stainless is identified, if not they may be really cheap and that may explain why the zinc/chrome are more expensive. There are good SS hinges available and they will usually say something like "all marine grade SS" or "all 316 SS".
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 11-22-2009
The Seadog hinge is 304 stainless.
Old 11-22-2009
jrd22's Avatar
Courtney the Dancer
If it's built heavy enough for what you want it to do that should be fine. 304 is actually stronger than 316 but not quite as corrosion resistant. They make standing rigging out of both 304 and 316. 316 is much harder to work with and polish and costs more.
John
SV Laurie Anne
Old 11-23-2009
I guess Perko is just a more expensive brand, unfortunately the hinges I'm removing are Perko, so most likely I'll stick with this brand so that the hinge screws line up properly with the current holes. Any idea how long I can expect the chrome plated zinc to last in a marine environment?
Old 11-23-2009
Don't use chrome plated zinc or other zinc-containing alloys on a boat if it is on salt water. The zinc will eventually corrode away and leave you with nothing usable. Personally, I'd recommend going with 316 SS hinges...but they're not always available.
Old 11-23-2009
tommays's Avatar
My PERKO 1981 chrome plated J24 stuff is still working and is just starting to get a bit fugly
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 11-23-2009
That's interesting. My Perko's are coming off a 1980 Eastward Ho, they may also be originals. Looks like the life span's about 25-30 years, not too shabby.
Old 11-23-2009
mitiempo's Avatar
Zinc plated will last a lot longer inside the boat than outside exposed to the elements. The op didn't say where the lockers are. I use stainless wherever I can. My original cockpit locker hinges are chromed over either brass or bronze. They look good after 32 years - just a bit green where the chrome has worn off.
Brian
Old 11-23-2009
Brian
They're in the cockpit.
Combination stainless steel chain/ galvanized steel anchor Grigrigrigoris Gear & Maintenance 11 07-03-2005 03:46 PM
Stainless 101 sailnaway Gear & Maintenance 2 01-28-2005 05:02 AM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 08:00 PM
Rust Never Sleeps John Kretschmer Buying a Boat Articles 0 02-27-2003 07:00 PM
Rust Never Sleeps John Kretschmer Gear and Maintenance Articles 0 02-27-2003 07:00 PM
