11-23-2009
SaltwaterSuzi/CapnLarry
As a guy who used to do a LOT of varnishing on other people's boats - I can tell you this - stay away from the Murphy's soap - if you ever intend to put another coat of varnish down. Don't use wax, either.
More than once I fought with trying to remove the residue from wax so that varnish could be applied without getting fisheyes all over. And I can tell you that Murphy's is even worse.
Hunter, and most manufacturers, don't do maintenance on boats - they build them and sell them. If they had to do the maintenance on them - they'd probably build them a lot differently.
Just clean your sole with something like Simple Green - very diluted. And every couple of years, lightly sand and apply another coat of what ever Hunter used - some use a water based varnish, some polyurethane, some regular varnish. Whatever you start with, stick with. But if you wax or put murphy oil on it, yer screwed.
Our sole was crap from when we bought the boat - we finally replaced it with teak and holly vinyl (!) from Lon Seal. Great stuff - looks real, and zero maintenance - except of course for cleaning. We put it in almost 5 years ago and it still looks new.
Saltwater Suzi and Cap'n Larry
"A sailboat is a fickle mistress. You’ve got to buy her things. You’ve got to understand everything about her. What you don’t know she’ll use against you." -Captain Larry
