11-28-2009
okay as for the distance to taper, you can run the taper around corners. also you can do half the taper on the out side and half on the inside, its actually the best way.
after looking at the pic again what i would do, is to taper it out as far as you can. then use a piece of g10 as a filler, or even make your own filler board. the filler is just a bunch of glass and resin made up to the thickness you need, then cut to fit the hole nicely. then after glass the out side, then add a layer or two on the inside.
doing this there is a chance it might crack under sail, but thats what the extra glass on the inside is supposed to mitigate
