11-25-2009
Unpaid Intern
Originally Posted by Vasco
If there is no drain plug you need to shove a thick piece of wire up the "in" hole which is the cold water entry at the bottom of the tank. This has a no return valve in it - hence the piece of wire. This will drain the tank - 4,5,6 gals?
Ahhh, I did think of that possibility, but wasn't sure. Sooo, the no return valve is keeping it from emptying, and the wire will open the valve, correct?
Next question--will the tank empty completely from the "in" line, or will there still be water in there? I'd LIKE to not have to put any antifreeze in there, so I don't have to worry about running the engine while the water heater is winterized.
By the way, it's 6 gallons. I can't get a big container underneath the drain location, so I suppose it's OK to drain into the bilge (the water isn't hot)?
1984 Sabre 34 Mk I
