11-26-2009
I don't discuss my member
Yes, you could perform your own hull cleaning. The basic tools would be a 3M "Doodlebug" scrubber (the abrasiveness of which is dependant on the amount/tenacity of the fouling you intend to remove), a wire brush for the running gear and a 6" scraper to take off any shelled animals. Depending on what brand of zincs you buy, you will need a flathead screwdriver or a set of metric allen wrenches to remove/install them. A hammer is handy to really set the zincs well on the shaft. Many divers (myself included) like to use a suction cup or plunger to give them something to keep them close to the work. I make my own but West Marine sells these if you wanted to buy one.
Bear in mind that since you will be working near the surface, you will likely want to wear more weight than you normally do when doing recreational diving. A lot more, unless you want to be really postively bouyant. Also, if your boat is plugged into the shorepower, be sure to unplug it before getting into the water.
Edit: Just realised you have a Coronado 25, so disregard the part about zinc installation. ;-)
"Clean bottoms are FastBottoms"
