New Anchor - Page 2 - SailNet Community
post #11 of 23 Old 11-27-2009 Thread Starter
night0wl's Avatar
Originally Posted by JohnRPollard View Post
What weight claw are you using now?
Our boats have similar displacement. I would spec the 33/35 Rocna/Manson.
At some point, going too large for the working anchor becomes a hassle and liability. The 33/35 is still manageable if the windlass fails, and is less likely to damage the boat or cause an injury. You can carry a second anchor to use in series when dire conditions are predicted, or stow a larger storm anchor below.
Unfortunately, I'm not at home to just go into the backyard to see the size of the claw. But here is a video tour I made where you can see the anchor (briefly). YouTube - Jendai Sailboat Tour
My current claw "feels" undersized...as with anything you get from the manufacturer or dealership from a production builder. Hence the desire for a more capable anchor. I'll demote the claw to a storm / second anchor once I have the proper sized next-gen
S/V Jendai
Beneteau 343
night0wl is offline
post #12 of 23 Old 11-27-2009
Unfortunately, there is no clear answer to the size debate. It comes down to how often you use the anchor and what role you see it playing. If you anchor out 2-3 times a year on calm nights with a good forecast, the 33/35 is definitely the way to go. However, if you really don't like moorings or docks or anchor in places with poor holding bottom, you might consider the next size up. If you travel far from your home mooring/dock and will sometimes need to anchor out in gale force or worse conditions, then the heavier anchor probably makes sense.
The sizing chart from rocna is probably the most honest chart on the market as far as sizing recommendations. There are way too many variables to get a truly accurate chart but the charts published by most manufacturers is basically for a lunch hook not a real anchor whereas the rocna one is a good place to start.
Personally, I use a 33lb Rocna on a 30' 10,000lb boat. This boat is right on the border with the 25lb anchor but I chose the heavier anchor for several reasons. The two biggest ones are being able to sleep better at night (I dislike docks and moorings) and the fact that I am often several hundred miles from my mooring and can't run home for a storm. If I had a windlass, I probably would have gotten the 44lb because of these storms.
klem is offline
post #13 of 23 Old 11-27-2009
Moderator
JohnRPollard's Avatar
Hard to tell from the video, but that claw doesn't look like the 15kg version. Maybe it's the 10kg (22lb), which would be on the small side for your boat. You could bump up to a larger claw for relatively small change...
JohnRPollard is offline
post #14 of 23 Old 11-27-2009 Thread Starter
night0wl's Avatar
Good point...the 15kg claw is only $100 vs $400 for either the Manson or Rocna. Thats a lot of boat bucks.
S/V Jendai
Beneteau 343
night0wl is offline
post #15 of 23 Old 11-27-2009
I'm one of those who thinks no anchor is ever big enough, but I know that isn't very reasonable.
What are you pretending not to know ?
Please support my
wind_magic is offline
post #16 of 23 Old 11-27-2009
mitiempo's Avatar
I don't understand why you'd use a lighter anchor and keep one a bit heavier for a storm anchor. I'd use the heavier one and sleep better. If as has been said you're going to only anchor a few times a year in calmer conditions I think the 33 lb Rocna is a good choice. If on the other hand you're going to go offshore and rely on your anchor a lot more I'd go with one size up. I agree with dog that the Rocna is better built than the Manson. I agree with klem on sizing. I currently have a 25lb CQR but won't replace it with a 22 lb, but a 33 lb Rocna. Boat is 27', 6100 lbs designed disp but easily 1500 more ready for offshore. And you have a windlass - I don't.
Brian
mitiempo is offline
post #17 of 23 Old 11-27-2009
Moderator
Originally Posted by mitiempo View Post
I don't understand why you'd use a lighter anchor and keep one a bit heavier for a storm anchor. I'd use the heavier one and sleep better....
Another way to look at it is, why would you use a storm-sized anchor for routine use when you don't need it? Wear out your back and/or windlass for what?
Putting two anchors in series is a good compromise.
post #18 of 23 Old 11-27-2009
mitiempo's Avatar
For a good sleep. I look at a good anchor as insurance. Interesting comments from Steve Dashew who has a great deal of real world experience. He considers manufacturers tables as a joke. He suggests a 30 to 40 foot boat use a 60 lb anchor, if it is a modern one like a Rocna and all chain rode. I realize there are many people anchoring their 35 ft boat with a 12 lb Danforth high tensile - after all Danforth states it's good for boats up to 42 ft in 20 knots! I just hope they don't anchor upwind of me. When people laugh at how big your anchor is compared to theirs I think you're on the right track. See this link for Steve's comments.
SetSail Blog Archive How Big Should Your Anchor Be?
Brian
mitiempo is offline
post #19 of 23 Old 11-27-2009
I am a firm believer in 1 large primary anchor and a second "storm" anchor. This comes from having spent thousands of nights on the hook at this point and having dealt with many different situations. Knowing that your anchor is overkill will let you sleep even when there are thunderstorms or wind forecast(maybe a bit more lightly then).
A lot has been written about putting 2 anchors in series and I have tried it once just to see for myself. It is very difficult to tell if both anchors are set and a veer in the wind direction will cause problems.
Putting 2 anchors out in a V is definitely a viable technique but you shouldn't be doing it everytime it is blowing. The biggest advantage to this method on a lot of modern boats is that the bow doesn't blow around as much. Still, if you get a wind shift, all of the load is on 1 anchor and if you are sailing on the hook, it will momentarily alternate between anchors.
I see an anchor as an insurance policy. I spent 9 years working on a 70GT vessel that had to lay to its anchor when things got rough since there were no other options and we were always thankful that the anchors were very large. Over the years, we watched plenty of yachts drag their anchors because the wind shifted or picked up just a little bit. Even when people woke up, they often didn't have time to react before being up on the beach. In my opinion, both setting ability and holding power are key to a good anchor.
There are some people who will claim that you need an even bigger anchor than I do. Many of these people feel that if you are trying to enter a harbor in 50 knot winds and associated winds and your engine dies, your anchor should be able to hold you through the storm. Knowing that I will see 50-60knots or more at least once a season on the hook makes me agree with the wind but I don't expect my anchor to hold in open water with the waves.
klem is offline
post #20 of 23 Old 11-28-2009
For a good sleep. I look at a good anchor as insurance. [...] I just hope they don't anchor upwind of me. When people laugh at how big your anchor is compared to theirs I think you're on the right track. [...]
Originally Posted by klem View Post
[...] This comes from having spent thousands of nights on the hook at this point and having dealt with many different situations. Knowing that your anchor is overkill will let you sleep even when there are thunderstorms or wind forecast(maybe a bit more lightly then).
I like these comments a lot. I think there is too much talk in anchoring about what is convenient and easy to use, etc. That does figure into it, the anchor isn't any good if you can't break it free from the bottom and get it back on the boat, but shouldn't our first priority be making sure we don't end up on the beach ?
I don't have much experience compared to most of you guys, but I won't let that influence me when I am choosing ground tackle. I want super heavy, lots of anchors, lots of rode, lots of options. The anchors in my estimation are one of the most important things on the boat and I'd go without a radio before I'd go without heavy anchors.
I see no reason not to go with the largest anchor you can handle every single time you anchor. The only justification someone could have for not using the largest anchor they could deploy and retrieve is convenience. For me that means 80+lbs with chain, and I don't care if its a 40 foot boat or a 25 foot boat so long as I can set it.
If I was in an anchorage and I watched someone drop a 100+lb anchor off the bow of their 30 footer, I wouldn't laugh, I'd just smile and think to myself that they've been there done that, and got the anchor to prove it.
You can have too much sail, you can have too much keel, too much hull, etc, but can you ever really have too much anchor ? At some point it becomes a weight issue, sure, you wouldn't put an 80lb anchor on your sailing dinghy, but it seems like above about 20 feet in length you are reaching the point where whatever a human being (and windlass) can deploy and retrieve is best, just my opinion.
Please support my
The Second Anchor Tom Wood Seamanship Articles 0 07-06-2004 08:00 PM
The Second Anchor Tom Wood Gear and Maintenance Articles 0 07-06-2004 08:00 PM
Choosing Anchors, Rodes, and Windlasses Liza Copeland Seamanship Articles 0 01-19-2003 07:00 PM
Choosing Anchors, Rodes, and Windlasses Liza Copeland Gear and Maintenance Articles 0 01-19-2003 07:00 PM
Choosing Anchors, Rodes, and Windlasses Liza Copeland Cruising Articles 0 01-19-2003 07:00 PM
