3-blade fixed prop recommendations? - Page 3 - SailNet Community
 3Likes
post #21 of 29 Old 09-28-2012
Re: 3-blade fixed prop recommendations?
It's been a long time since I sailed in Maine-unfortunately-so I can't remember what kind of seaweed you encounter up there. Here on the outer Cape, we have quite a bit of a type of seaweed which looks like big clumps of sawgrass floating just below the surface; only once have I had a problem with it. Not long after I first installed the new prop, I was running from the mooring to the town dock and suddenly all hell broke loose; all kinds of vibration and noise, and the boat slowed down to a crawl. Of course the first thing I thought of was the prop was coming off, the shaft was bent, etc. etc. I went to neutral and looked over the transom, and saw a huge bunch of this weed trailing from the screw. I reversed a couple of times and it came off. Knock on wood, hasn't happened again. I can't say that this wheel is more susceptible to fouling than what I had before-the only thing that ever fouled my 2-blade was a length of 5/8" nylon line, leading to my first working experience with a scuba tank! I should note that my prop is also in an aperture, cut into the deadwood ahead of my barn door-style rudder.
Catboatfan is offline
post #22 of 29 Old 09-28-2012
This is exactly what I experience, except it happens all the time! I often end up getting in the dinghy at the end of the day to pull seaweed from the prop.
I wonder why my setup is such a seaweed magnet?
Could it be the gap between the and of the bearing and the start of the prop?? Perhaps I should try a shaft zinc in front of the prop to take up the space. ?
Preserved Killick
Seagrass
Boothbay Harbor, ME
Alberg 30:
preservedkillick is offline
post #23 of 29 Old 09-28-2012
Maine Sail's Avatar
That's odd. This summer it happened just twice to us but I never noticed any difference in frequency between the CS and our old prop.. We had a LOT of weed this summer too. To free it I just give a quick blast of revers and it's gone. I would think we'd get more with a fin keel but perhaps not...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #24 of 29 Old 09-28-2012
I see you have an external bearing support, thus the prop is much farther away from the deadwood; on my boat it's very close to the deadwood as the cutless bearing is pressed into the deadwood itself. In fact, there's no room for a zinc ahead of my prop; I use a "doughnut" zinc clamped to the propeller nut. You might try a doughnut zinc ahead of the prop and see if it helps.
post #25 of 29 Old 09-28-2012
Catboat fan,
How close to the bearing is the front edge of your prop hub?
I agree, I'm going to dive next time I go to the boat and add a shaft zinc.
-pk
Preserved Killick
Seagrass
Boothbay Harbor, ME
Alberg 30:
post #26 of 29 Old 09-29-2012
I've only got about 1/2 or 3/4 inch space there-not enough for a zinc.
post #27 of 29 Old 09-29-2012
You could possibly cut or have machined a zinc to be narrower.
DoubleEnder is offline
post #28 of 29 Old 09-29-2012
I used to do this with my old setup. I'd buy the thinnest ring-type shaft zinc and just grind it down myself with a bench grinder. Took about a half hour, but it worked well.
Preserved Killick
Seagrass
Boothbay Harbor, ME
Alberg 30:
post #29 of 29 Old 09-29-2012
old guy :)
rikhall's Avatar
We have a "fin keel" on our Irwin Citation 34 and we bought and installed a Campbell Sailor this past spring and used it this summer.
Our old Michigan three blade (I called it a "tug boat prop") was a major weed magnet and nothing would get the weeds off except going for a swim.
Like Maine Sail says - a quick bit of reverse (usually) takes the weeds off the new Campbell Sailor. Two times this summer, once off Petit Manan and once just off The Wolves in the Bay of Fundy it took a quick swim to get them off.
So, I happily add my recommendation for the Campbell Sailor prop.
Rik
Irwin Citation 34
Mystery
rikhall is offline
2 Blade vs 3 Blade prop PBzeer Gear & Maintenance 23 01-02-2007 09:43 PM
Inboard fixed vs. folding prop & ratings mikehoyt Racing 6 06-06-2004 10:07 PM
lowest drag for fixed 3 blade? e31 Gear & Maintenance 3 04-19-2004 08:26 AM
Three Blade Prop KenD Gear & Maintenance 4 10-21-2003 06:39 PM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
