11-29-2009
Originally Posted by JVallely
The 3 pairs of original bronze-bushed aluminum masthead sheaves on my '79 Alajuela 33 cruiser were grooved for wire and rope.
I want all 7/16" rope for simplicity's sake, so I need rope grooves. Machining the old ones will still leave me with about 3 1/8" diameters (7.1 times rope dia.), and aluminum obviously has greater strength.
New Delrin sheaves would be lighter, a little bigger at 3.5" diameters (8 times rope dia.) probably cost not much more than the machine work, and entail less chasing around.
Is there a significant reason to go one way or the other--i.e, re-machine and reuse the aluminum sheaves, or buy the new delrin ones?
Or is it a coin-toss?
Thanks for your thoughts.
John V.
The only reason not to reuse the existing sheaves that I can think of would be if the reduced diameter led the halyard too close to the lip of the spar and a chafe point was created.
As long as the sheave is big enough to turn down, you will probably save some money.
Ron Paul 2012
"wikijar"
