Help! Metric prop shaft creating road block! 1972 Dufour Arpege. - Page 3 - SailNet Community
post #21 of 27 Old 11-30-2009
Sounds to me like a used shaft in SAE (US demenisions) is your best way to go, as it will give you much more in options as far as props and hardware. It may not be what you want to do, but lets look at what went wrong in the first place;
1. You lost all the hardware that holds on the prop
2. The zinc is no longer attached ?
3a. The prop fell off while under way ?
3b. The prop is gone.
5. The prop shaft is damaged ?
6. The prop shaft threads are damaged ?
Buy a shaft and prop and move on, and perhaps increase your mantinence on the shaft/prop/zinc assembly in the future.
Good luck
Kary
SV Mariah #49080
75R20 is offline
post #22 of 27 Old 11-30-2009
tommays's Avatar
Ya
But then he needs a cutlass bearing and coupling and
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #23 of 27 Old 11-30-2009
Angry
Originally Posted by tommays View Post
Ya
On a vessel of that age, might he need these anyway ? I would think that loosing a prop, while the engine was running might have caused damage to these parts with the assoc. vibrations caused by a loose prop nut/prop.
Kary
SV Mariah #49080
75R20 is offline
post #24 of 27 Old 12-01-2009 Thread Starter
OK. Here's where I stand. I've ordered the 25mm prop nut, lock washer, and anode from Beneteau. ($50.00) I've been advised they'll fit. When they arrive, I'll go swimming to confirm fit. If that works out, I've found a 12 x 8 LH with a 1 1/8 inch bore ($200.00) and a bronze reducer bushing ($86.00) to take the bore down to 25mm. If it all works (we'll see) then I'm back out sailing for $386.00. Less than an new prop, new shaft, new cutlass bearing, new stuffing box and new coupling... say $900.00-$1,000.00
Wish me luck!
Lawson Mitchell
lawsonmitchell is offline
post #25 of 27 Old 03-04-2010
Have Arpege prop
I repowered my 1972 Dufour Arpege about 3 years ago and
have the original prop.
Do you want it.
Eddie
ehjumpstar is offline
post #26 of 27 Old 11-12-2013
Send a message via Skype™ to pelias
Re: Help! Metric prop shaft creating road block! 1972 Dufour Arpege.
Originally Posted by lawsonmitchell View Post
I can't seem to find any local shops willing to deal with getting a prop to replace the one I lost over two weeks ago! Help. I don't think I can afford a new prop shaft, cutlass bearing, stern gland and coupling just to switch to a 1" prop shaft. And no one wants to venture a guess as to the right diameter and pitch to the prop without seeing the old one. Well, if I hadn't have lost the old one, I wouldn't need a new one!
I want to go sailing again. HELP!
Lawson
can you help me do you think?
hello i hope your well i wonder if you can help me,
do you still have the dufour arpege 30? i am looking to change the cutless bearing as ours has worn out. can you give me any advice on this please, and might you have any pictures.
thank you in advance
Richard
pelias is offline
post #27 of 27 Old 11-12-2013
There are online shops, with all sorts of Beneteau used parts, in France. They are cheap and ship.
sony2000 is offline
1 inch prop on 25mm prop shaft? lawsonmitchell Gear & Maintenance 12 07-12-2014 06:50 PM
Changing prop underwater trantor12020 Gear & Maintenance 16 03-03-2007 12:02 PM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
Drive Train Vibration Tom Wood Gear and Maintenance Articles 0 10-10-2002 08:00 PM
