Old 12-01-2009
trantor12020's Avatar
trantor12020 is on a distinguished road
looking for water pump grease
I read somewhere here that for greasing job underwater one can use water pump grease as it does not wash off easily. Can someone advise me the brand of such grease? Thanks.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
Old 12-03-2009
groundhog is on a distinguished road
Not sure what you are trying to do, but would toilet ring wax work? Home Depot for $3.
Old 12-03-2009
trying to grease prop shaft to prevent barnacle growth.
Ken
Old 12-03-2009
timebandit's Avatar
timebandit is on a distinguished road
BTG or Boat Trailer Grease should work.
It is a wheel bearing grease made for water.
Try NAPA.
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
Old 12-03-2009
Valiente's Avatar
I have never been able to find "water pump grease" as recommended for my Oberdorfer pump on my Atomic 4, but I understand it's a waxy, solid grease stick: you cut off a chunk and press it into the grease nipple and then turn the cap until snug, giving it a quarter turn now and then to get fresh lube to the pump shaft.
I've seen it on an old guy's boat, but as I said, I can't find such a product, so I use a big blob of peanut-buttery bearing grease, which is similar to "white lithium grease".
Can't sleep? Read my countdown to voyaging blog @
Old 12-05-2009
Shortman is on a distinguished road
I use Star Brite white teflon lubricant on winches, or if you want to pay more you can buy a winch grease with a winch mfg's name on it. I also second the trailer bearing grease idea.
Old 12-05-2009
mintcakekeith is on a distinguished road
Rocol saphire aqua 2 .I use it for winches etc keith.
Propshaft-- Converting old grease pump system kaakre Gear & Maintenance 0 01-27-2007 10:19 AM
Devising a Better Bilge Pump Don Casey Seamanship Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Gear and Maintenance Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Cruising Articles 0 06-02-2002 08:00 PM
