12-05-2009
Tartan 27' owner
Dan,
I have seen people do epoxy/fiberglass repairs when it is in the 40 - 50 degree range on the hard. They use a tarp(s) to tent the area in and use some kind of heater to get the ambient temp around the repair area to about 70. The higher the temp the quicker the epoxy will set - as you know. I'm a West Systems kind of guy and would use the 205 fast hardener as I have seen it kick in about an hour at 80 degrees. I forget if the slower hardeners have more tolerance for lower temps.
Good luck.
