Old 12-07-2009
dillybar is on a distinguished road
Cleaning & polishing gellcoat non skid
So what's every one using to clean the waffle texture gel coat on the top sides. I'm in the PNW and the black dock grunge that gets tracked on the boat is the issue. I've used Ajax with a stiff brush but it's probably not so good for the gelcoat?
Old 12-07-2009
Ajax is probably a bit abrasive. We've been using an inexpensive low powered pressure washer.. takes a while but gets into the pattern nicely. Tried a non-skid cleaner/polish this fall but less than impressed. I've heard good things about "Woody Wax" and will try that in the spring.
1984 Fast/Nicholson 345
Old 12-08-2009
tommays's Avatar
Ajax and Comet do not have the grit level it use to and at least on my older 1981 boat it gets the stuff off and its allready as faded as its gonna get
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 12-08-2009
Large Member
mdbee is on a distinguished road
"Soft Scrub"
Old 12-08-2009
14432's Avatar
14432 is on a distinguished road
I have always been impressed with Simple Green and a stiff brush.
Old 12-08-2009
QuickMick's Avatar
QuickMick is on a distinguished road
for wax
ive been using nufinish, the once a year carwash to polish. for the bad stains i was using a bit of acetone. found the gas powered heavy dooty powerwasher knocked off most of the crap. i have wasted more money on products that dont actually do anything... but make my arm sore.
Oh, and the magic eraser really is magic...that thing rocks
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 12-08-2009
October Moon B43
MJBrown is on a distinguished road
When they get too bad and deck cleaner wont take them off I use a small medium strength bristle brush and a cleaner wax. I then use a terry cloth towel to buff it off. The cleaner gets the spots off but leaves a protective coating between the no skid so the deck stays cleaner longer. So far I haven't run into any issue with the deck being slippery after I'm done. BTW I also do this periodically on the cockpit sole and floors in the heads. A lot of work but well worth the effort.
Old 12-08-2009
JiffyLube's Avatar
Grasshopper
JiffyLube is on a distinguished road
For those dark spots down in the deep recesses of the non skid that don't want to come off, I pick them out with a nail then clean the deck. My wife and I each took one side of our 36' boat, and it took us about two hours to pick all that stuff out. It's been about a year since we did that, and no more black spots have returned. Picking it out was time consuming, but it did the job.
Old 06-08-2010
jjablonowski's Avatar
jjablonowski is on a distinguished road
I second the plaudits for Mr. Clean Magic Eraser!
Mr. Clean Magic Eraser Original
Old 06-08-2010
oomfh is on a distinguished road
Originally Posted by mdbee View Post
"Soft Scrub"
. . . with Bleach . . .
bottom cleaning SFWindChaser Gear & Maintenance 10 11-27-2009 10:41 AM
Spring Hull Cleaning Tom Wood Gear and Maintenance Articles 0 04-05-2004 08:00 PM
Sail Care and Cleaning Kathy Barron Gear and Maintenance Articles 0 10-20-2003 08:00 PM
Cleaning Fiberglass Hulls and Decks Sue & Larry Gear and Maintenance Articles 0 03-07-2002 07:00 PM
Cleaning Fiberglass Hulls and Decks Sue & Larry Her Sailnet Articles 0 03-07-2002 07:00 PM
