Old 12-08-2009
QuickMick's Avatar
QuickMick is on a distinguished road
breaker box
the previous owner of my boat appears to have begun a rewire project and abandoned it. he cut holes in a piece of balsa wood to mount switches, of which only 3 are wired (exterior lights) there are lots of wires running to the harness, but im thinking they will only be good to pull new stuff through.
ive got two fuseplates from other boats i was thinking of employing, but wondered if there is a good company that provides aftermarket control panels?
thanks
Quinn
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 12-08-2009
nickmerc's Avatar
nickmerc is on a distinguished road
I am a fan of Blue Sea Systems. I rewired my boat last year and went with thier stuff. For good prices check out Peter Kennedy Yacht Services. He is not local to you, but the savings will definitely cover the shipping. There are those on this forum who will try to steer you away from Peter. Talk to Peter and get quotes before you make a decision.
________
TSSweetAngel4U
Old 12-08-2009
QuickMick's Avatar
thanks bud, great info!
Quinn McColly
Yacht Broker
Old 12-08-2009
mitiempo's Avatar
I'd second Blue Seas - they're my first choice for all electrical.
Brian
Old 12-08-2009
QuickMick's Avatar
Any rough approximation of total $? nickmerc you just re-did yours? 30' boat, about 10 switches, on two batteries... inverter seems good. new box, new cables... and who knows what else i may uncover...
Quinn McColly
Yacht Broker
Old 12-08-2009
tommays's Avatar
Mick
8271 panel
Were is the BOX as on my A4 CAL 29 its in the motor area which requires ignition protected breakers AND Blue Sea makes very nice series of panels in 3,4,6 and 8 breakers Horizontal or Vertical that Meets UL 1500 and ISO 8846 ignition protection requirements
I am going with this panel or combo of them when i know how many breakers i want and there 7650 add a battery as it keeps the starting and house battery separate and auto charges as required
In my search its the cheapest thing for a small electric system
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 12-08-2009
St Anna's Avatar
St Anna is on a distinguished road
I would purchase a larger panel than you first calculate.
I have always found a later need for another fused switch (or 2). Ours is obviously a different need to yours, but in the photo, I have used the blanks.
http://i665.photobucket.com/albums/v...a/P2090095.jpg
Old 12-08-2009
QuickMick's Avatar
hmmm...ive got a switch labeled ignition, but it is not wired, yet oddly the key fires the engine... think this is a safety hazard of immediate concern?
Quinn McColly
Yacht Broker
Old 12-08-2009
Waltthesalt is on a distinguished road
I concurr with Blue Sea as being the best. When I rewired my Cal-29 I mounted new fuse switch panels on plastic "project boxes" that I got at Radio Shack and also from online vendors. Besides cost my reason for this DIY approach was several fold: I wanted to meet the ABYC standard for an fully enclosed pack on the panels which backed into the engine compartment; I wanted to do a second level of fused distribution inside the box behind the switchboard of some of the switches e.g. a switch for cabin lighting on the front panel feeding separately fused lighting circuts inside (one blows and I still have hald the lights); and finally I couldn't find commercial products with the switches I needed that would fit into the space I had available.
Old 12-08-2009
QuickMick's Avatar
also... the inverter is good, ive got the heavy duty guest bat. selector... if im redoing the other stuff is there a compelling reason to address the working parts i now have?
thanks gang
Quinn
Quinn McColly
Yacht Broker
Refrigeration—Part I Tom Wood Gear and Maintenance Articles 0 04-28-2003 08:00 PM
Installing 12-Volt Refrigeration Sue & Larry Gear and Maintenance Articles 0 06-18-2002 08:00 PM
