Old 12-08-2009
davidpm's Avatar
davidpm is on a distinguished road
Idea for turnbuckle cotter pins
How to secure cotter pins in turnbuckles seems to evoke a range of advice.
Most people insert the cotter pin. bend the legs back and cover with rigger tape.
Some people say the tape encourages crevice corrosion and makes them hard to inspect. They recommend to tape but bending the legs back and around far enough so they will not catch on sails.
I just saw another way.
The sailor had a piece of Velcro about 6" long and 3/4" wide. Pushed through the end of Velcro and the head sewn in with sailor's thread was fixed a cotter pin. The legs were left straight.
The way it was used is that the pin is put in the turnbuckle hole. The Velcro was wrapped around the turnbuckle. The pin could not fall out due to the circle of Velcro. It was loose enough to drain water. It is easy to remove to inspect.
What do you think?
Old 12-08-2009
amarinesurveyor is on a distinguished road
I don't think it is as secure as a cotter pin. With time the ends of the cotter pin will chafe through the velcro that is deteriorating from the UV in sunlight.
What's wrong with a simple cotter pin? and no need to tape it if you direct the pointy ends inboard and bend them back. Keep it simple stu... ;-)
Brian
Old 12-08-2009
tommays's Avatar
I race on a lot of boats EVERYBODY uses TAPE they don't make cocoons around it and they don't have issues as most of the taped areas take such a beating it gets redone a few times a year.
When your running jib sheets and spinnaker sheets and guys and 4 halyards stuff gets caught on stuff
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 12-08-2009
NateCP16 is on a distinguished road
There is a commercially available velcro-type product that is popular with the trailer sailing crowd.
Wrap Pins
West Marine: Wrap Pins for Turnbuckles Product Display
Old 12-08-2009
sailortjk1's Avatar
Also popular with the racing crowd that adjust and tune a lot.
Courtney is My Hero
Old 12-08-2009
mitiempo's Avatar
I agree the velcro isn't as secure as a cotter pin being bent. But they should only be bent about 15 degrees, not 180. The other solution is to use split rings. As far as tape, just around the cotter pin not the whole turnbuckle. Another solution is a dab of silicone on the cotter pin end. One of the few uses for silicone on a boat.
Brian
Old 12-08-2009
sailortjk1's Avatar
Do you have first hand knowledge of the product in the link?
Properly installed, they work fine and are very convenient for fine tuning and retuning.
Courtney is My Hero
Old 12-08-2009
mitiempo's Avatar
No, but I wouldn't trust my rig to a strip of velcro. I like secured cotter pins.
Brian
Old 12-08-2009
davidpm's Avatar
Wrap Pins
That's exactly what it was. I thought it was home made. Thanks.
Old 12-09-2009
tommays's Avatar
As the guy checking the tape Those would be toast in a one hour 4 leg W/L race as the Velcro will snag sheets and get tugged
Tommays
Northport NY
leak-proof keel stepped mast idea deckhanddave General Discussion (sailing related) 27 03-31-2010 02:24 PM
thru-hull electric connector - at least 13 pins skysurfer Gear & Maintenance 2 06-28-2006 09:07 PM
