diesel tank cleanout - Page 2 - SailNet Community
post #11 of 31 Old 12-09-2009
RichH's Avatar
J34035-
Since you have an inspection port you can easily get inside with a long handled scrubbing brush dipped into 'garage floor cleaning compounds'. These compounds will tend to soak up a lot of the semi-liquid crud and when they 'dry' can easily be handled. Otherwise, just knock the crud to the bottom and then soak up with paper towels ... which you will later 'burn'.
Recent commercial developments by some manufactures of chemical 'tank cleaners' will make your job easier (and dont need the tank to be removed - too late on your part). These 'cleaners' emulsify/dissolve the fungal crud from the tank walls, prevent the future agglomeration (small particles sticking together making larger and larger particles) of particles but let those unagglomerated particles freely pass through the 'common' fuel filters. "Starbrite Tank Cleaner" , etc. is one of such products that have great promise in remedying a very nasty job of 'tank cleanout'. You might want to slosh one of these chemical tank cleaners inside your already removed tank as an aid to your clean-out.
To prevent such fouling in the future, only keep in your tank the amount of fuel you NEED (plus some reserve), DONT continually top it off, remove the fuel when the boat is inactive for loooooong periods of time (ie.: winter). OR install a high flow recirculation polishing system that continually filters the fuel when the engine is running.
RichH is online now
post #12 of 31 Old 12-09-2009 Thread Starter
"Sparkie"
j34035's Avatar
Thanks for the feedback. Just as a note, this boat (and tank) is almost 20 years old and as far as I know, has never been pulled and cleaned, so I figure it is due. I do try to keep only the diesel in that I need and I have an external pump with a filter to clean or polish the fuel to about 10 microns. I will look at Starbright as a cleaner and this weekend will pull the access cover to see what I really have to deal with. Hopefully it is not too bad. My goal is to go back next spring with a totally clean fuel system and avoid the clogged fuel filter problems I had this year. Always happens at an inconvenient time (is there a convenient time to have a problem?). Thanks to all, good advice.
DD
Doug
Jboat J/37c (new to me Jan 2011); J/22 #1003
j34035 is offline
post #13 of 31 Old 12-09-2009
One of None
deniseO30's Avatar
all that sludge may be keeping the pinholes from leaking if its' that old. Knowing what I know now. any old tank should be replaced (imho). new ones really aren't that expensive.
My last project!
deniseO30 is offline
post #14 of 31 Old 12-09-2009 Thread Starter
"Sparkie"
j34035's Avatar
That may well be good advice. Putting a leaking tank back into service would be not so much fun. Thanks for that heads up.......
DD
Doug
j34035 is offline
post #15 of 31 Old 12-09-2009
mitiempo's Avatar
Replace it with new and you should be good for another 20 years.
Brian
mitiempo is offline
post #16 of 31 Old 12-09-2009
Good Call!!
Faster is offline
post #17 of 31 Old 12-10-2009
2nd mate
For an easy clean: pour in 2 litres (that's metric system) of gasoline.
Swirl around an pour it out, you will see the sludge come out with it.
Repeat as needed..
The small amount of gasoline left (after you poured it out) will do no harm to the engine, because its so dilluted w diesel.
Easy and cheap.
The big advantage is that you don't have to thoroughly dry the tank as you would have to w water.
Grtz from europe :-)
bartvdv is offline
post #18 of 31 Old 12-10-2009
Not just a member
tank clean
I removed my 18 gallon Monel fuel tank and cleaned.
1)removed the remaining fuel (took it home and mixed it with my tractor fuel)
2)Rinsed tank out with 2qts mineral spirits, with a handful of (steel) nuts in it. Used tape to seal the openings, then rolled the tank over and over in every direction.This way it loosened any on or behind the baffles. Poured out the mineral spirits in suitable container.
3) Used 1qt of West Marine citrus bilge cleaner and 2 gallons water and repeated the rolling process. poured out soap mixture.
4) inspected tank with flashlight and extendable inspection mirror.
5) Removed the (steel) nuts witha magnet, (thats why I used steel nuts stainless will not stick to a magnet)
6)Rinsed tank with lots of freshwater.
7) used a wet dry vac. to get out as much water as possible.
8) poured in 2 qts. Isopropyl Alcohol , taped openings and rolled it around. Poured out alcohol.
9) Left the tank in the Sun for 2 hrs. with the inspection port up, any water and acohol then evaporated.
26 yr old tank looked brand new. Cleaning it was the easy job. Getting it in and out out was tough. Comleted whole job with new fuel lines and vent hoses and gaskets. In a long 10 day.
Dan
"Wind Wing"
Piewiet 850 / Dutch Flyer 28
Solomons, MD
Chesapeake Bay
"For the truth is that I already know as much about my fate as I need to know. The day will come when I will die. So the only matter of consequence before me is what I do with my allotted time. I can remain on shore, paralyzed with fear, or I can raise my sails and dip and soar with the breeze."
Richard Bode
-- from First You Have to Row a Little Boat
motovationcycles is offline
post #19 of 31 Old 12-10-2009
RichH's Avatar
mmmmmm..... maybe the organic acids in all that sludge is 'causing' the pinholes.
Pin holes in fuels tanks are easy to repair ..... just cut the top of the tank open (large 'sister flanges'), clean the tank, apply fiberglass tape to all the weld seams, and then 'line' the whole tank with a thickened epoxy or cloth and epoxy. Can be done 'in' the boat.
RichH is online now
post #20 of 31 Old 12-10-2009
RichH's Avatar
If you ever sell this boat, remove the tank and keep it. Nothing beats MONEL for fuel tanks. Of course you'd need a second mortgage these days to buy a MONEL fuel tank.
RichH is online now
Converting water tank to diesel tank - fittings? Zanshin Gear & Maintenance 5 09-15-2009 05:38 AM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Replacing the Diesel Tank Sue & Larry Gear and Maintenance Articles 0 09-18-2002 08:00 PM
Diesel Engine Woes Mark Matthews Gear and Maintenance Articles 0 09-19-2001 08:00 PM
