diesel tank cleanout - Page 3 - SailNet Community
post #21 of 31 Old 12-10-2009
Originally Posted by RichH View Post
If you ever sell this boat, remove the tank and keep it. Nothing beats MONEL for fuel tanks. Of course you'd need a second mortgage these days to buy a MONEL fuel tank.
Hey Rich,
I know you too have a T-37. I had a survey done about 2 years ago and the surveyor said that my fuel tank was Monel. Had you ever heard of a Tayana having Monel? My hull # is 448(built in '85) and I did hire a person there in Taiwan to oversee the production back in '85. He was a solo sailor who lost his sailboat in the South China Sea and needed work. I think his background was aero engineering and with both of us having engineering backgrounds, we communicated quite well, but at no point in time was there a discussion about changing the material of the fuel tank to Monel. The specs on the boat calls for "black iron".
Dee
lancelot9898 is offline
post #22 of 31 Old 12-10-2009
Learning the HARD way...
eherlihy's Avatar
I thought that everyone knew this trick;
1. Rinse tank with mineral spirits
2. Add a 3 lb bag of ice cubes from your local store
3. Add hand-cleaner/degreaser
4. Shake vigorously (as much as possible)
5. Drain any liquid and crud
6. Rinse with water
7. Let dry
- Ed
eherlihy is offline
post #23 of 31 Old 12-10-2009 Thread Starter
"Sparkie"
j34035's Avatar
6. Rinse with water
7. Let dry
- Ed
That sounds like a pretty good plan. After I get the thing cleaned out, I can pressure test to see if it leaks. Probably not an issue putting about 5 psi on it and using a soap solution on all the joints. I am also looking to see what a replacement tank costs. Lots of good ideas here. Thanks
DD
Doug
Jboat J/37c (new to me Jan 2011); J/22 #1003
j34035 is offline
post #24 of 31 Old 12-10-2009
Closet Powerboater
MedSailor's Avatar
Toilet brush and some elbow length PVC gloves are what I used. I think I may have used dish soap as well, can't remember. After I was done with that I polished it with paper towels. No chemical is going to clean the tank as well as you can with good old elbow grease.
The only "trick" I did was fill the tank with water and add biobor jf to the water to make a very strong solution. I let that sit for a day or so. I figured that would sterilize what was already clean.
Now I'm still on the same filter as I was 2 years ago.
MedSailor
MedSailor is offline
post #25 of 31 Old 12-11-2009
RichH's Avatar
Originally Posted by lancelot9898 View Post
Hey Rich,
Dee
My Ty37 (#423) has a black iron tank that I 'relined' with FRG/epoxy. Monel would most probably have been a special order ... a very 'wise' special order.
FWIW - its easy to 'reline' the black iron (bow) tank on a Ty37 ... using WEST and FG tape, etc. The Ty37 black iron tank rots from 'underneath' if you dont keep those limberholes clear and occasionally flushed out.
RichH is offline
post #26 of 31 Old 02-13-2010
remove and empty the tank
put in 3 or 4 cups of clean fish tank gravel with 1/2 gal. of paint thinner
seal the tank and flip it over 50 or 60 times in all directions
pour off the thinner
repeat until the thinner pours off clear
shake out the gravel
add clean thinner shake, turn and pour it off
the tank will be spotless
Arclight is offline
post #27 of 31 Old 02-14-2010
DD
5 PSI would turn your tank into a worthless balloon, if it doesn't rip apart and kill someone. This really isn't a safe thing to try unless you really really know what you are doing. I damn near overpressurized some test plugs rated for 7 psi on a piping system because the brand new gauge was defective! If it wasn't for a second gauge in the system we wouldn't have realized the first one was bad until it was too late!
Gary H. Lucas
Gary H. Lucas
GaryHLucas is offline
post #28 of 31 Old 02-14-2010
mitiempo's Avatar
5 psi is standard for testing a tank. My new stainless tank was tested to 5 psi - I watched it being built and tested because the welder is a friend. He used soap and an ultrasonic tester as well (a system where the escaping sound is amplified to headphones - makes a small leak sound nice and loud). But Gary is right - make sure it's no more than 5 psi as thay puts a fair amount of stress on the tank.
Brian
mitiempo is offline
post #29 of 31 Old 02-14-2010
I cleaned my 20 gal aluminum tank by swishing acetone around in it...letting is sit, and repeating a few times. then I let it evaporate dry, and to be abosolutely sure, I rinsed again with clean deisel and emptied it. It's back in the boat and working fine after two seasons. I guess there are a few ways to skin this cat.
Pub911 is offline
post #30 of 31 Old 02-15-2010 Thread Starter
"Sparkie"
j34035's Avatar
Lots of good ideas here, but how do I get rid of all this $^%## snow so I can get in the shop and get some work done?
DD
Doug
j34035 is offline
Converting water tank to diesel tank - fittings? Zanshin Gear & Maintenance 5 09-15-2009 05:38 AM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Replacing the Diesel Tank Sue & Larry Gear and Maintenance Articles 0 09-18-2002 08:00 PM
Diesel Engine Woes Mark Matthews Gear and Maintenance Articles 0 09-19-2001 08:00 PM
