12-09-2009
Originally Posted by mitiempo
farmuse
I don't think that would make much difference. The crud in the tank can't get past 2 filters anyway, so they clog. If you're getting soot and black smoke it means unburned fuel. The reasons could be a dirty bottom, clogged or restricted exhaust elbow (common), or injectors need retipping and are giving the engine the wrong amount of fuel.
Most of the particulates that form inside diesel fuel tanks are soft/deformable and will easily 'extrude' through common fuel filter media under increasing 'differential pressure' across a filter set. These particles 'can' then after extrusion can quickly reform into LARGER particles by the processes of 'coalescence' and 'agglomeration'.
Many of these particles are the byproducts of the metabolism of the fungi which are the principal cause of tank fouling, these byproducts usually contain broken down long chain molecules that reform into 'alkenes', which dont 'burn' well in the combustion chamber and sometimes freely pass downstream of the combustion chamber (as liquids) to deposit and form 'coke' in the hot exhaust sections of the engine.
