12-10-2009
Misanthrope
Working my way through the posts in order:
Changing "the jet" will not do anything as you have to change both jets for each elevation range:
InternetOutboards.com - High Altitude Jet Kit, 6600 Feet, Nissan/Tohatsu, 4-Stroke, 9.8 hp, All Models, FREE SHIPPING
InternetOutboards.com - High Altitude Jet Kit, 3300 Feet, Nissan/Tohatsu, 4-Stroke, 9.8 hp, All Models, FREE SHIPPING
It's a must do as the power loss is about 50% at 9000 feet. Even changing them out with the above kit your still going to lose a little at anything above 8000. Smart money says change them out for each specific elevation or lose power even though its a pain. Conversely, changing them out for elevation and then running them back at a reduced height is an extremely bad idea. Think in terms of metallic dispersion in an energetic manner bad. You must change them back or the term "lean" will come complete with an audio from your engine as the thing begins to sound like nails on a chalk board. That's an exaggeration of course  But, you get the point.
The 1-17 screw is an idle speed adjustment screw and does not make the engine rich or lean. EPA requirements in the U.S. require "fixed" settings so engines are no longer able to be legally tweaked that way....There is a hidden mixture screw, but you do not want to drill your carb to get to it as you could not adjust it enough to make a difference for altitude.
With the proposed 15% alcohol dilution for fuel in the works and the proposed catalytic converters requirement in the works things are going to become very dicey for outboards over the next five years. Alcohol, at 10%, is already pushing the envelope as far as outboards are concerned. Running lean, as alcohol content increases, will be an issue.
Dropping the prop pitch isn't a bad idea, but it can't make up that kind of difference on a simple, small outboard. Larger, smarter engine's with Hal 2000 ECU's can vary the settings by themselves and compensate for a lot, but the usually limit is about 4000 feet and then you start wondering why you can't pull your fat a@@ brother-in-law up on skis anymore
Elvin
Solution One Maritime
