Old 12-10-2009
waltsn is on a distinguished road
Nissan/Tohatsu 9.8 high to low altitude
Since the Tohatsu guru is visiting here.. I have another question.
I will normally use this engine for a couple months at 5000 feet el, most of the summer it will be used at 8600 feet el
But for a week, I will use it about about 3000 ft el. At at the 3000 foot elevation, the motor is run a LOT. If Im lucky on time (not likely), I could even use the outboard at lower elevations.
Because of the normal use mostly between 5000 to 8600 feet, Im getting a "high altitude jet". Im hoping this makes the engine start easy at 8600 feet as Ive had lots of trouble in the past (part of the reason I also want electric start).
But if I leave the high altitude jet in the motor and use it at 3000 foot where it might be run for 8 hours at a time, am I at risk for overheating and damaging the engine? Im going to get both jets and learn how to swap but am wondering what the risk is..
Old 12-10-2009
pedcab's Avatar
pedcab is on a distinguished road
In my opinion, probably not. I suppose that what the "high altitude jet " does is to provide a leaner mixture for the engine to be able to cope with the thin air at altitude.
Your moving to a lower altitute (higher pressure, "thicker" air) place while maintaining a high altitude jet will result in a leaner mixture and I think that will not cause your motor to overheat... It may cause it to have to run with the choke actuated for larger periods though...
In fact if you learn how to tune a carburettor you won't even need to change jets, having just to slightly tweak the mix everytime you move up or down in the barometer...
Pedro
Portugal
Old 12-10-2009
tommays's Avatar
The motors are already lean and theres nothing you can tweak its all fixed jets
IMHP if your jet is correct at 8600 it will be to lean at 3000 and lower and make a lot of heat
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 12-10-2009
pedcab's Avatar
t
Are they? You can't lean or enrich the mixture?
So whas the purpose of the 1-17 screw?
Pedro
Portugal
Old 12-10-2009
tommays's Avatar
Well in the good old days my Johnson motor had adjustable low and high speed jets RIGHT on the front of the motor
The good old days are gone on USA motors
Tommays
Northport NY
Old 12-10-2009
pedcab's Avatar
In fact they did. My father still has one in perfect running condition. Here´s one just like it
But the picture I've attached is, in fact, of a Tohatsu M5 engine carburettor and the 1-17 part sure seems to me like a mixture adjustment screw, being 1-15 the throtlle stop which acts as an idle speed adjustment point...
So do they or do they not have an adjustable mixture rate?
Pedro
Portugal
Old 12-10-2009
tommays's Avatar
I never seen anything other than idle speed on a newer USA motor
Even the inboards that still have carbs have the idle mixture screw capped off and you have to break it and replace it with one from and older motor model if you want to adjust it
Tommays
Northport NY
Old 12-10-2009
pedcab's Avatar
Well, in that case, I'm sorry for you guys...
Arround here every 2 stroke carburettor fed outboard I've ever seen features an acessible mix adjustment...
As I've said before in other posts it amazes me the American government policy of being so environmentaly conscious about outboard engine's emissions and other minor polluters and being so permisive about motor sports and absurdely oversized car engines of any kind. Maybe one of those jet boats of yours running on Chinook reactors burns more fuel in a qualifying run than 1000 small sailboat outboards in a year...
PS: What do you mean by "newer"?
Pedro
Portugal
Old 12-10-2009
tommays's Avatar
There is 1,2 and 3 star motors mine is a 2 star about 2004 in age
You gotta see whats coming gas inboards are going to catalytic converters and diesel is next on the list
Tommays
Northport NY
Old 12-10-2009
pedcab's Avatar
We have a saying here that sure fits you like a glove: The worse part of any sailing boat is its motor
Good luck then...
Pedro
Portugal
Nissan/Tohatsu 9.8 charging system waltsn Gear & Maintenance 12 12-10-2009 07:26 PM
With winds low, regatta woes high (Baltimore Sun) NewsReader News Feeds 0 04-30-2006 10:15 AM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
Understanding High-Pressure Systems Michael Carr Seamanship Articles 0 04-06-2001 08:00 PM
