Old 12-10-2009
QuickMick's Avatar
QuickMick is on a distinguished road
insulation? Daft with a Draft
It has been unseasonable cold down here in North Texas (last night 19 deg!), which caused me to notice something. If im buttoned up in the vee berth, w/ceramic heater and door closed im toasty warm... but in the cabin w/same heater i couldnt seem to get it over 52ish... i noticed a slight draft, part of which im sure is coming from the drop in slats, but it seemed that some of it was coming from under the cockpit through the engine compartment.
have any of you put any kind of insulation between cabin/cockpit to address a similar issue, or have any other suggestions. whatever i do, i would also like to help keep the cool from the ac in in summertime...
thanks
Quinn
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 12-10-2009
You may very well be getting draft from the lazarette/cockpit area - often times those aft "bulkeads" don't extend fully up into the coamings and can be sources of cold air in winter. Crawl around the quarterberth and look into the engine compartment looking for such pathways.
Closed cell foam such as that used for sleeping pads for campers (eg 'Ensolite') is a good way to block these types of leaks, and can also be used as an insualation material for the inside surfaces of the hull (ceilings) and overhead. Being closed cell it will not hold moisture.
1984 Fast/Nicholson 345
Old 12-10-2009
Irrationally Exuberant
arf145 is on a distinguished road
Don't know your boat specifically, but I can say that I was amazed at the number of ways air could get between the cockpit locker and the interior on our Pearson, mainly in the aft cabin. I wasn't trying to stop cold, just locker odors, but in our case the cabin liner wasn't designed for an airtight fit. I'd look for that kind of stuff, and as far as your engine compartment goes, there's usually an air duct from above so the engine can breathe. At 19 deg that might be felt.
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 12-10-2009
Not just a member
motovationcycles is on a distinguished road
Take a towel and drape it over the dropboards. Then slide the hatch closed. It will seal along the top better and stop the drafts between them.
Dan
"Wind Wing"
Piewiet 850 / Dutch Flyer 28
Solomons, MD
Chesapeake Bay
"For the truth is that I already know as much about my fate as I need to know. The day will come when I will die. So the only matter of consequence before me is what I do with my allotted time. I can remain on shore, paralyzed with fear, or I can raise my sails and dip and soar with the breeze."
Richard Bode
-- from First You Have to Row a Little Boat
Old 12-10-2009
Architeuthis is on a distinguished road
And of course always be aware of condensation. That dang mold will take advantage of every opportunity.
The drafts always remind me that monohulls without air tight sections are only a pinhole leak away from Davy Jones.
First Boat - Draft Advice nolesailor Boat Review and Purchase Forum 4 11-19-2009 01:49 PM
Insulation ... Cal28 Gear & Maintenance 1 11-14-2009 09:36 PM
Hunter 37 Cutter deep and shallow draft donrr1 Hunter 0 10-28-2006 11:45 AM
How Much Draft? Cheetie Cruising & Liveaboard Forum 2 04-28-2002 12:21 AM
Shoal Draft Cruisers Sue & Larry Buying a Boat Articles 0 02-20-2002 07:00 PM
