Old 12-13-2009
lapworth is on a distinguished road
Top Painting
Is it ok to top paint why your boat is in the water? Do you think I could do a nice job without taking all the fittings off ?
Old 12-13-2009
fordo is on a distinguished road
I assume you are painting the deck, rather than the topsides(the area between the waterline and the gunwales) since you mention fittings. If you are changing the color at all you should remove the fittings. If you are painting the same color it is still better to remove the fittings. It is possible to paint around the fittings if you're very good and very careful.
If you paint in the water you must be careful to keep the paint out of the water and the water out of the paint. You also have to watch the rigging and the mooring lines to keep them away from the paint.
Old 12-13-2009
canadianseamonkey's Avatar
Caribbean Surveyor
canadianseamonkey is on a distinguished road
It's hard enough painting on the hard, I can't imagine painting while she's rocking. Some marinas won't let you because of environment issues, so best to check with them first. I would haul her out if you could and do it right.
Old 12-13-2009
petmac is on a distinguished road
Do it on the hard and take the fittings off. If she is a Bristol with a cored deck, check for delamination/saturated core and repair before refinishing. I ran into core problems on a Bristol 30 that I owned at one time.
Old 12-13-2009
tager's Avatar
tager is on a distinguished road
It would be possible to do it in the slip. Just make sure you have a shop vac to pick up any sanding dust. I would stop being vain and go sailing.
Old 12-13-2009
Dec. through Feb. are maintenance months is it really that vain to fix up your boat in the of season ? I am trying to keep cost down my job isn't very stable in this economy.
Old 12-13-2009
Nothing vain about fixing up your boat. Messing around with boats is part of the fun.
Old 12-13-2009
imagine2frolic's Avatar
imagine2frolic is on a distinguished road
Nothing wrong with trying to keep her appealling to your eye. If the boat has known issues as typed above. I would look for 4 those, and get rid of them, and then doll up the deck.
Removing everything will make it look better, more proffessional. It also makes it easier in the long run............i2f
20 MPH ain't fast unless, you do it in a 1000sq 3/2 house on 10foot waves
BORROWED, No single one of us is as smart as all of us!
Old 12-13-2009
tommays's Avatar
You need dry weather above 50 deg F which is gonna be a tall order right now
I have a 55 DEG HEATED indoor area were i sprayed my mast last winter and it took a long time for the paint to dry
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 12-13-2009
We get warm days in the winter around here plus some global warming.
Top 10 Sailing Venues Dan Dickison Cruising Articles 0 08-11-2002 08:00 PM
Painting a Boot Top Tom Wood Gear and Maintenance Articles 0 09-26-2000 08:00 PM
