Old 12-13-2009
TommyD's Avatar
'74 C&C 33'
TommyD is on a distinguished road
swage fittings
I have running backstays, one of which has a snag new this year. I will need to go up the mast to cut off the swage fittings. What's the best way to do it, & to put up new stays? I'd like to do this in as few trips as necessary.
'Nora Mae Rose'
Portsmouth, RI
Old 12-13-2009
jmolan's Avatar
jmolan is on a distinguished road
I made up my replacement running backstays with Dynex Dux. Then it was a simple project to go aloft with both replacements and switch them out. I do not understand why you would want to cut your fittings. The should have a pin ad cotter pin set up.
Only one trip up the mast needed. The runners are really light and easy to handle now. I got the rope and fittings here....Home
(time spread between) Alaska, PNW, & Mexico
Old 12-14-2009
CaptainForce's Avatar
As posted above, I also see no need to "cut". I understand the possibility of the one trip, but I usually remove the old shroud and use it to confirm the measurement for my replacement and take the second trip up the mast. 'take care and joy, Aythya crew
Standing Rigging Basics Mark Matthews Racing Articles 0 08-29-2004 08:00 PM
Whisker Pole Fittings Thermal Gear & Maintenance 4 07-28-2003 06:26 AM
Swaging Fittings Tom Wood Gear and Maintenance Articles 0 04-24-2002 08:00 PM
